Old 09-08-2008, 12:45 PM   #1 (permalink)
Question P4 to Core 2 Duo/ Core 2 Quad
I have a P4 PC of LG and i wanna know how do i get to know is ma pc is compatible wid Core 2 Duo/ Core 2 Quad????
tarundham is offline
Old 09-08-2008, 12:49 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: P4 to Core 2 Duo/ Core 2 Quad
what motherboard your system have. Read motherboard manual, or visit motherboard manufacture's website to find compatible processors.
ravi_9793 is offline
Old 09-08-2008, 12:53 PM   #3 (permalink)
Question Re: P4 to Core 2 Duo/ Core 2 Quad
actually dude i do not know as ma pc is of lg and how do i check dat??
Old 09-08-2008, 01:09 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
use google to search for a software named CPU-Z to help that part.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 09-08-2008, 03:19 PM   #5 (permalink)
ok dude i downloaded dat software it checked ma pc now plz temme wat to look out for
Old 09-08-2008, 03:20 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
If your system has windows XP.
start -->> Help and support -->> Use Tools to view your computer information and diagnose problems -->> My computer Information -->> View general system information about this computer
You can find detailed information about your system configuration here.
Old 09-08-2008, 03:38 PM   #7 (permalink)
Exclamation Re: P4 to Core 2 Duo/ Core 2 Quad
arre bhai wat i was talking was dat i have downloaded cpu-z and how do i know wats ma motherboard
Old 09-08-2008, 04:32 PM   #8 (permalink)
darklord's Avatar
Check the 'Mainboard' tab in it.That will give info about your mobo.
darklord is offline
Old 09-08-2008, 06:45 PM   #9 (permalink)
It's MANUFACTURER IS- "MICRO-STAR INTERNATIONAL CO. LTD
and MODEL NO. IS-"MS-7137" REV:1.0
Old 09-08-2008, 08:57 PM   #10 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
hey why dont you search for your motherboard's manual(most of the branded computer companies give them in your mottherboard's cartoon) that will give you complete information about all upgrades if not then check the MSI website and search for your motherboard's model(basically they are categorised by chipset-types)........
but if you cant do this then you must know that most motherboards support further upgrade compatibilities upto 6-12 month of upcoming products...... and you know when you bought your pc... and when the C2D's and C2Q's came into market.......
Sooraj_digit is offline
Old 09-08-2008, 10:14 PM   #11 (permalink)
It's probably a 915 chipset...
If so there's no way you could use a dual core or c2d with it.
Check the ram wala tab in cpu-z whether it is DDR1 or DDR2..
Let there be music.....
sashijoseph is offline
Old 09-08-2008, 11:46 PM   #12 (permalink)
Its a 945G chipset(dat's wat i get to know from ma driver's CD)
and my RAM tab shows DDR
so plz tell me is it compatible??????
Old 10-08-2008, 12:22 AM   #13 (permalink)
newer 945g express then it might support core 2 duo and that depend on manufacturer model..
older 945g do not support the new cpu i think
MS-7137 seem like it is used oem for small form factor pc branded by other company
http://global.msi.com.tw/index.php?f...2_no=&cat3_no=
looks like chance of yours supporting core 2 duo is near zero
realdan is offline
Old 10-08-2008, 10:24 AM   #14 (permalink)
Red face Re: P4 to Core 2 Duo/ Core 2 Quad
Hey i bought it in January 2006 so is der any chance???? or i have to buy a new pc for c2d???
Old 12-08-2008, 06:44 PM   #15 (permalink)
Tux Fan
shaunak's Avatar
I think you will need a Mobo update.
Jan 2006 means that its probably a 945G/P, which is incompatible with the Core2 series. The first chipset to support the Core2 released in June 2006.
945GC codename:Lakeport G is the only 945 to support the core2 and it was released in Jan 2007.
So outta luck buddy...
Intel release dates ::Here::
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Quad Core & HDDs The Unknown Hardware Q&A 4 26-03-2009 10:55 PM
Quad Core or Core 2 Duo jerin3013 QnA (read only) 5 04-01-2008 07:42 PM
Help in configuring a quad core Pc eureca_eureca PC Components / Configurations 2 04-08-2007 08:13 PM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
Move over Core Duo.. Quad core is here anispace Technology News 2 29-06-2006 12:25 AM
