Old 07-08-2008, 01:08 PM   #1 (permalink)
Default No Dispaly Problems
Hi
I m using Branded Hp PC Model no. m7360in
I get The BLUE SCREEN OF DEATH atleast once a day
Os is Xp media Center
Problem:
Suddenly one morning my pc was not starting.
No display on monitor
I thought there is prob with monitor as the cpu was making fan noise buut then i noticed that nothing was working
all usb dead , cd rom not opening then i relaised it is CPU Problem
PC is branded so engineer Called up HP and hey came to my place after 3 days
ssaw the problem and replaced my motherboard
still same problem
then as soon as i remove the gfx card it works fine so they ordered a new gfx card for me . but then too PC does not work.
But both the graphic card works well on other pc
So in short, my motherboard has been changed,gfx card has been changed, hardisk is one click format
Still PC is not running with the graphic card on it
So suggest me something guyz
( It has been 21 days Since HP Guyz are coming and going but no solution. they have demanded a new motherboard again.)
great_dindi is offline
Old 07-08-2008, 03:02 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: No Dispaly Problems
change the PSU & check.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 08-08-2008, 08:04 PM   #3 (permalink)
The HP Guyz changed the Motherboard and the graphic card
Everything is fine now
Old 08-08-2008, 08:11 PM   #4 (permalink)
moshel's Avatar
check the mains from where ur PC gets the power. u have a UPS? or spike guard?
moshel is offline
Old 09-08-2008, 03:45 PM   #5 (permalink)
guyzzzzzz problem is back this morning plzzzzzz help
almost every part of cpu is replaced
for moshel:
No UPs
No Spike Guard
For UPS i have a Compuinverter
FOr the multiple switches i hav added a 8 socket board on the wall
i tried moving the pc to other room still did not work
Old 09-08-2008, 05:10 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
^check the PSU
Old 09-08-2008, 08:19 PM   #7 (permalink)
wat to check in it and how ??
Old 09-08-2008, 11:20 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
change the PSU (try ur friend's PSU)
Old 09-08-2008, 11:56 PM   #9 (permalink)
i would suggest you to call an electrician to your house to check if anything wrong with earthing and neutral..a leakage of current in the earth and neutral could fry your motherboard and other components gradually...the leakage is not normally detected with the usual current tester.
realdan is offline
KDE problems! Need help ! Dark Star Open Source 6 25-02-2008 11:06 PM
Post ur mobile internet queries, problems n problems here sourishzzz1234 Buying Advice 2 19-01-2008 07:34 PM
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
OS problems .......... please help!!! Mohnishgs Software Q&A 4 14-05-2006 12:24 AM
DISPALY IMAGES !! bala4digit QnA (read only) 4 20-08-2005 07:04 AM
