Old 05-08-2008, 02:28 PM   #1 (permalink)
Kalyan's Avatar
Question Trouble with Sony DRU 190A DVD Writer
I got this Sony DRU 190A DVD Writer. Recently, it is showing a strange problem. it is getting detected as a drive but it is not able to read any disk. it is not even trying to do so. (ie., the disk is not rotating and the drive does not seem to respond). though it is showed as the drive in the os. Even when I insert a bootable disk in the drive, it is not being detected or boot from the drive. I opened the drive and connected to see what is happening. When a disk is inserted, the disk is spinning for 2 secs, the laser is blinking 2-3 times. and the disk spinning is stopped. the disk does not rotate there after. the eject and insert are going well when I am pressing the button on the drive and also when I am doing it through the OS. In Vista, when I try to open the drive, it is ejecting automatically and prompting to insert a disk.
I downloaded the firmwares for this drive. does re-flashing the firmware fix the drive? Is there any other way?
Which is the best SATA DVD Writer available? Are there any issues with SATA drives as of now? which is better? SATA or PATA?
Please help me with this issue... Thanks a lot....
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 05-08-2008, 10:01 PM   #2 (permalink)
Default Re: Trouble with Sony DRU 190A DVD Writer
uninstall the drive from device manager
then reboot
try in another PC
claim warranty
realdan is offline
dvd writer problem sony Sony AW-G170A brijand Hardware Q&A 6 25-07-2008 11:35 AM
My new sony DVD DRU 190A 20X takes 1hr 15min to write 1DVD?????? bravo007 QnA (read only) 7 18-06-2008 01:03 PM
Cd Writer Trouble :( forever Hardware Q&A 4 30-11-2006 12:35 PM
DVD writer trouble umapati Hardware Q&A 6 28-06-2006 06:17 PM
Which dvd-writer sony dw-q120a or sony dru-820a its urgent anirudhasarawgi Hardware Q&A 3 27-05-2006 05:47 PM
