Hi Everybody !
I was also going to ask nearly the same question. Here I go:
Best mobo+proccy combination under 10K for Intel/AMD !!
I am going to upgrade the motherboard and processor of my system. My budget is strictly 10000/-
After serious considerations and reading through forum posts, I’ve come upon this conclusion:
AMD SOLUTION
PROCESSOR:AMD Athlon X3 8450 @ Rs. 5500 /- + VAT
Mobo: (780G BOARDS)Gigabyte GA-MA78GM-S2H @ Rs. 4400 /-
PRICE:For AMD setup with 780Gboard; that makes it 5500+4400 = 9900/-
INTEL SOLUTION
PROCESSOR:Core2Duo E7200 Rs.5600/-
Mobo: (G-31 BOARDS)Gigabyte GA-G31M-S2L Rs.2800/-ASUS P5KPL-VM >>2850/-ASUS P5KVM >>4500/-Is there any value-for-money budget P35 Board that can be used costing between 3-4.5 K?
PRICE:For INTEL setup with G-31 board; that makes it 5600+2800 = 8400/-
Out of the above two, which is a better combination. In this table AMD solution looks to be a better bet. As of now, I am interested in onboard graphics. GPU can be added later, if at all required. Please note that I will be using the system mainly for movie encoding, database applications/programming Visual Studio, photoshopping, casual gaming etc.
After reading Legion Hardware's post at
http://www.legionhardware.com/document.php?id=751&p=0, I feel that for non-serious gamers....E7200 is a better option !
