My current configuration is.
Intel Core 2 Duo E6320 (1.86GHz)
Asus P5NE-SLI Motherboard
2GB RAM @ 533MHz
20x DVD Writer
Creative Audigy Value 7.1
A 250GB 7200 rpm Hard Disk( Seagate I think)
450W Supercomp Power supply
And also 5 Fans (2 at Front, Back and one on the side)
The issue is that i've bought a new graphics card. An EVGA 9600GT KO Edition. My vendor says that a 450W power supply is insufficient and that i should go for atleast 600W.
Now my questions are:
1. Is what he says true? If that is the case then i plan to go for an SLI rig later on, and possibly some overclocking/upgrading. What supply should i go in for to be safe in the future?
2. I read some articles about hooking up two Power supplies together. How safe is it and has someone out here actually done it? If so, then will one dedicated 450 W power supply be sufficient for two cards to run in SLI?
The second questions answer would be more important as i'd get to save some cash...
