Old 02-08-2008, 08:09 AM   #1 (permalink)
Default Not connecting to internet Unless restart
Iam running Win Vista ultimate
Using Bsnl home 50 plan
Modem SmartEX MT822 Connected to onboard lan slot
Mother board Abit ip 35 e
Iam facing a problem in connecting to internet once i switch of the modem . only a restart can connect to internet if modem is turned on again
Please help me fix this .
eureca_eureca is offline
Old 03-08-2008, 02:19 PM   #2 (permalink)
Default Re: Not connecting to internet Unless restart
I've only dabbled in Vista so far, but since no one with more experience with Vista has offered a solution yet....... Do you have two firewalls running - Windows' and a third-party FW, including any FW that comes with your anti-virus? More than one firewall running at the same time can cause problems with a network. Also, I suggest you give more details about how your network/internet connection is set up.
pimpom is offline
Old 03-08-2008, 03:58 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
right click on the "network" icon on the task bar -> diagnose->reset modem.
now the internet shuld work.
if it does, then you've done something wrong in configgin the modem/ in netwrk properties windows.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 03-08-2008, 10:23 PM   #4 (permalink)
Havent touched yet any thing in the properties , this modem dosent have a proper driver too (for vista) so connected via lan
No pcs connected on network , using only kaspersky windows firewall is disabled .
Last edited by eureca_eureca; 03-08-2008 at 10:24 PM. Reason: Automerged Doublepost
Old 03-08-2008, 11:10 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
1
2
3
4
5
Old 05-08-2008, 03:11 PM   #6 (permalink)
I got the message
What to do next
What is that "more than one active netowrk" ? ? ? , whats causing this ?
And my download an upload speeds are very low , i used to get 2 mps on rapidshare premium , now i dont get
Last edited by eureca_eureca; 05-08-2008 at 03:58 PM. Reason: Automerged Doublepost
Old 05-08-2008, 03:41 PM   #7 (permalink)
peeing on Assembly line
try restarting related services(network) using services.msc .
unban praka123 fsf.org <--- new revolution taking years but succeeding in a regular phase :)
humanbeing is offline
Old 06-08-2008, 06:42 AM   #8 (permalink)
didnt work !
1
2
3
4
5
It worked buddy , thanks for the help
Last edited by eureca_eureca; 06-08-2008 at 10:21 PM. Reason: Automerged Doublepost
Old 07-08-2008, 11:48 AM   #9 (permalink)
But hot to prevnt this from happening for ever , cos once the pc is restarted this same problem occurs ,and i have to disable one connection
Old 07-08-2008, 02:55 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
in IP properties, enter the respective values.
like 192.168.1.5 ......
dns....
Old 07-08-2008, 03:47 PM   #11 (permalink)
hie everyone ..
even i am facing similiar problem ... i am using dataone broadband which is connected through usb nd i am using xp
if i am connected to internet , then if modem resets due to voltage fluctution or somethin ... , then internet connection wont disconnect ...
then if i try to connect again through connect to it will giv a message like destination not rechable or somethin lik that
if i hav to connect again , then i need to restart the windows ... while restarting it will giv a message ... conenction tray is not responding
.. nd also if we cannot end explorer.exe through task manager ...
whts the problem
sweet fren is offline
connecting to internet sravan Internet & WWW 7 01-08-2008 12:51 PM
Connecting to internet sattumail Internet & WWW 8 28-02-2007 12:18 PM
Windows XP(Internet)problem?Windows'll restart within 15 Sec imprince Software Q&A 10 07-12-2004 01:22 AM
Xp restart when connected to internet vijaythefool Internet & WWW 8 07-10-2004 08:49 PM
