Old 02-08-2008, 07:43 AM   #1 (permalink)
Gizmo Freak !
spitfire's Avatar
Question Techcom SSD 670 with Vista x64 : Help Needed !
Guys.. I have a techcom ssd 670 internal tv tuner ~
Its a cheap card ..retails for about rs .9k ..but has awesome picture quality.I actually rate its picture quality higher than the pinnacle 50i i used to have.
It works perfectly fro 2k/xp systems and also has drivers for 32bit vista.
Recently I was thinking about shifting to 64 bit vista. I downloaded the MSDN edition , installed it..and OMG...It was far better performing in my hardware than the 32 bit one... everything installed perfectly...the only gripe being that now I have no drivers available for it for 64 bit vista.
So can anybody help me by providing generic drivers for the tv tuner chipset.
Googling isnt much of help. I've found a few but they are not working perfectly...for instance one driver installs perfectly...the card is also recognised ..but the channel scan doesnt work ... it just stuck with the last channel I've viewed..picture quality is awesome though
Chipset : Philips 7130/7134 analog
OS : Vista x64
Thnx in advance !
If nothing works..then I will put this card on sale in Bazar section...but thats something I dont really like to do atleast with this card.
spitfire is offline
Old 03-08-2008, 09:49 PM   #2 (permalink)
Default Re: Techcom SSD 670 with Vista x64 : Help Needed !
Does it work with Media Center in Vista? I think you're the same guy I sent a PM just now in another forum
PaulBarber is offline
Tv Tuner problem techcom internal ssd-tv 670plus vinay_001 Hardware Q&A 2 18-10-2007 11:09 PM
TechCom TV Card patkim QnA (read only) 2 04-07-2007 08:00 AM
Techcom webcam SSD641 MP hakim Software Q&A 2 03-02-2007 09:33 AM
techcom SSD KB 880 multimedia keyboard driver rahuljin Software Q&A 2 12-06-2006 12:18 PM
TechCom Speakers.......ur opinion nphanindra Audio 18 01-10-2005 04:15 AM
