Old 01-08-2008, 06:15 PM   #1 (permalink)
RexRazr's Avatar
Question network hub/switch
does anyone know about a network hub or switch that supports 35-40 meter ethernet cable?
how much does it cost?
AMD X2 6000+@3.2GHz | XFX nForce 8200 HybridSLI | 4 GB 800 MHz DDR2 | XFX 8800 GT 512 Alpha Dog XXX | Seagate 320 GB Barracuda + Hitachi 250 GB DeskStar | Cooler Master Extreme Power Duo 600 Watts
RexRazr is offline
Old 01-08-2008, 07:01 PM   #2 (permalink)
Default Re: network hub/switch
All standard hubs and switches support that length of cable and more. The limit is usually given as 100 metres, but you can get away with even longer lengths if the cable is of good quality and is not placed near sources of electrical inteference.
A switch is better than a hub as it is 10 times faster and can prevent or reduce problems due to data collision. An 8-port switch costs roughly Rs.600-1000 depending on the brand.
pimpom is offline
Old 03-08-2008, 11:19 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
these days most switches & hubs support upto 100m cable len.if u use good quality cable and gigabit speed u wont feel much diff if u exceed this limit
hellgate is offline
Old 03-08-2008, 11:28 PM   #4 (permalink)
filth is me
forever's Avatar
D link 8 port switch - Near Rs 1000 @ nehru place
TP link 5 port switch - mere Rs 400 (Its a chinese company)
forever is offline
Old 04-08-2008, 02:19 AM   #5 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Buy D-link 8port switch and D-link network cable it will work,i hav a 75m lan with my friend
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
KVM Switch... shivg33k Hardware Q&A 1 03-07-2008 02:32 AM
What will happen if i switch off the CPU FAN ? satyamy CPU / Motherboards 8 21-12-2007 05:06 PM
Compex Network Switch ajeesh Hardware Q&A 1 23-10-2006 03:12 PM
Switch or HUB? linardni QnA (read only) 7 22-08-2005 03:04 PM
Network Layer switch ilias Networking 2 25-03-2005 01:43 PM
