Old 01-08-2008, 04:41 PM   #1 (permalink)
Lightbulb my 1gb transcend pen drive does not work properly
When i try to copy some files to my pen drive from my home computer, it shows an error. "use the chkdsk utility" but the files shows in the drive. and when i want to delete the file it shows another error.." the directory is not empty" if it is directory. for filr it deletes that file but when i refresh it, it shows the files again. And i have to format the drive..
please suggest what should i do.
i use symentac antivirus, spybot search & destroy, and comodo firewall.
sumangh01 is offline
Old 02-08-2008, 06:54 PM   #2 (permalink)
Default Re: my 1gb transcend pen drive does not work properly
where did you buy it and for how much?
that means to delete file you have to format to do so..?
realdan is offline
Old 04-08-2008, 02:15 PM   #3 (permalink)
I bought it about a years ago for Rs.640. But when i copy some file from my office computer it works fine.
may be it is affected by virus. but i dont know anything more about it.
Old 04-08-2008, 03:44 PM   #4 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
there is a virus for sure on your computer download latest definition updates and let it go
Sooraj_digit is offline
Old 04-08-2008, 04:20 PM   #5 (permalink)
Certified Nutz
sreevirus's Avatar
Have you tried formatting the disk? I sometimes have faced the problem of corrupted files, and it usually gets solved after a format.
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 04-08-2008, 04:24 PM   #6 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Format it in safe mode
I spit Rainbows.
skippednote is offline
My DVD Drive does not work Properly. nshul007 Hardware Q&A 1 13-04-2008 07:48 PM
DVD drive not working properly.. windchimes Hardware Q&A 4 04-07-2006 08:17 PM
my sys not work properly mahesu_87 QnA (read only) 3 11-04-2005 05:58 PM
CD Rom Drive not working properly Tech&ME QnA (read only) 6 17-11-2004 01:04 AM
