Old 31-07-2008, 03:20 PM   #1 (permalink)
The Thunderer
bhutanesedude's Avatar
Default How to connect two PCs with bluetooth device...
Guys....Correct me if I am wrong but I want to connect my laptop (O.S Vista) with my Desktop (XP) via Bluetooth connectivity.....For now...i am just able to transfer files and folder via Bluetooth software..but not really making a network....
For an example....Say..If I want to play a network game between my laptop and desktop I need to connect these two PCs via Bluetooth....So I am nt able to do that.....
Does it works?
Please help me....
bhutanesedude is offline
Old 31-07-2008, 03:42 PM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: How to connect two PCs with bluetooth device...
the network u will make would be too slow
Better get a RJ45
I spit Rainbows.
skippednote is offline
Old 31-07-2008, 04:28 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
u can create a Bluetooth PAN to connect both but speeds will be very slow for gaming and large file transfers.
hellgate is offline
Old 31-07-2008, 07:56 PM   #4 (permalink)
The Thunderer
Yes, I am able to make PAN, but when I go to My Networks, it doesnot show my Computer, neither the shared files of other computer. It just shows that the BT is connected and connection Icon but I am not really able to use it as Network as like in General.
Is there any way of connecting two PCs via Network Cable without Hub? I mean like without Hub, Directly from Computer Network Modem to Modem....? Is yes...how do I configure it within a LAPTOP (Vista) and Desktop (XP).....Please suggest me.....
Old 31-07-2008, 08:26 PM   #5 (permalink)
Point Blanc
you need to right click and do Send To Bloothooth Devices and select the computer where you wanna transfer the file.
Bluetooth is not for gaming.
So do not say that gaming will be slow.
You need to have a protocol like that over bluetooth.
Bluetooth is generally connection based when you try to acquire some data connection is made and then it disconnects even though you feel to have that you are connected.
For establishing a connection between two systems you need a LAN cable.
ANd do little configuring of your network device.
you can try and search threads giving exact details of this in the Hardware Troubleshooting section.
acewin is offline
How to connect a usb device which the win xp says as UNKNOWN DEVICE? aQi_g Software Q&A 8 03-07-2008 03:59 PM
No Drivers for Bluetooth peripheral device gxsaurav Hardware Q&A 10 06-10-2007 01:39 AM
Driver For Bluetooth Device anilthomas26 Software Q&A 8 02-07-2007 04:03 AM
Suggest a Bluetooth Device for Connecting PC to Nokia 3650 quad master QnA (read only) 9 29-12-2004 01:19 AM
