Hi !
I have a situations here...
I have a old 80 GB parallel HDD (PATA) which I use as external USB storage by putting it to a 3.5" IDE-USB Hard Disk casing for more than 2 years,now the casing power source develop some problem and the HDD generates some issues & it need to format which via USB is not possible,It need to connect motherboard's direct IDE channel.
My mobo is Intel's 945 GTP which have only one Primary IDE port...
Here is my Cngifg
Intel P4
945 GTP
512x2=1GB 533Mhz Ram
1.44" FDD
160 GB SATA <----OS Bootable
Sony DRU-810A <---- Primary One as Master Settings
So here are my question:-
1 .If I connect it as a master by removing the DVD-RW (for a while)...will SATA HDD which contain OS can boot ? (and So I can format/partition the PATA drive)
2. As I don't want to purchase another casing or use the faulty existing casing,
I want to permanently keep the drive inside the cabinet..
So In this case what is the Jumper PIN settings between the PATA HDD & DVD-RW ?
As much as I know,
HDD is master & DVD-RW is slave....
3. In that case, is that DVD-RW drive will be bootable to read/load OS disc ?
In any situations my intention to
use the 80GB PATA as a extra storage &
160GB SATA as main/basic Hard Drive.
Please experts/geeks help me to set this.
Thanks in advance.
