Originally Posted by bippukt
Good to know that I can hook up my console to my monitor.
- For Xbox 360, I need the VGA cable and then it's simple enough. But it does not come even with the XBox Pro...where will I find the bloody cable as nobody seems to have it. But the component cable should be able to deliver acceptable graphics for the time being.
- For PS3, I still don't know if it's possible or not. And it does not seem to have a component cable either! Why do Sony people make it so hard to find such important info?
1. for 360 u have to use a HD-VGA cable. costs 1685. as of now for some time its not available in india. though u can order one from playasia.com.ther are third party ones, dragon cable for abt 500 or 600. enough. though u need buy the female to female connector for VGA. and the L-R splitter from audio extra. in orginal MS all are bundled.
or u can use the HDMI port if elite or halo edition or new falcons or jasper.
2. for PS3 u have to options
1. if ur LCD have HDMI port just buy the HDMI cable and connect it. simple.
2. u have to buy a HDMI-DVI cable and a DVI-VGA adapter if needed. and no HDMI-VGA is not available.
Originally Posted by moshel
1. Yes
2. dont know
3. even 17" dont look too bad. go for widescreen monitor.
4. nope. but get a monitor with good contrast ratio and a low response time.
4, for MS orginal cable for 360 and HDMI-DVI cable good ones no pblms...but the third party cable users for 360 have been complaining abt bad signals...some cases only...
Here are some questions that are making me mad:
1. Can I connect my future console to my LCD monitor (also in future)?
2. If yes, what do I need on the console side and on the PC side?
3. What size monitor will give you good display? I am thinking of getting a 19" or 22" (if affordable).
4. Any performance issues?
All this will help me solve my PC/XBOX/PS3 dilemma, even if I have to wait for a month or so
1.yeas.
2.read my other posts
3. buy the biggest maximum possible. 22" costs from 13k to 16k...worth it..
4read my other posts.
