Old 29-07-2008, 06:12 PM   #1 (permalink)
Good Boy
george101's Avatar
Default Seagate 500GB or WD 640GB???????
hi guys am planning to buy a new hdd... am confused whether to buy a seagate 500gb or WD 640gb... my budget is 4k..... guys plz recommend which one to buy and suggest which brand is better, seagate or WD????
i think seagate has 5yr warranty. what abt WD?
guys plz reply fast as am getting one within 2 days
george101 is offline
Old 29-07-2008, 06:45 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Seagate 500GB or WD 640GB???????
same warranty on both and WD 640AAKS has a much better support + reliability + performance + value for money
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 29-07-2008, 06:58 PM   #3 (permalink)
Good Boy
george101's Avatar
but r u using WD??? coz i hav been using seagate for all these years and dnt knw anythin abt WD... can i go with WD coz 640GB is a lot of data and i dnt want to loose it anytime soon......
Old 29-07-2008, 07:05 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Both are equally reliable companies. And yes, be careful with 640Gb.
desiibond is offline
Old 29-07-2008, 07:13 PM   #5 (permalink)
manishjha18's Avatar
seagate 500 gb has 32 mb buffer while wd has 16 mb --
manishjha18 is offline
Old 29-07-2008, 07:14 PM   #6 (permalink)
Alter Bridge=GOD
all my hard drives are WD except 2 which are Seagate Cheetah + Seagate barracuda
i'd always advice WD
also Seagate has improved a lot in past yrs with their reliability issues and one should not have a problem getting it.but performance+value for money is nowhere near WD640AAKS
practically it gives a slightly better read speed but its slow in write speeds
Old 29-07-2008, 11:15 PM   #7 (permalink)
Good Boy
george101's Avatar
wat do u mean by being careful?
Old 29-07-2008, 11:51 PM   #8 (permalink)
Lets Do It!
amrawtanshx's Avatar
Thats correct.
Drives with more buffer don't necessarily perform better.
And Seagate is fine too.(Replacement is easy & quick)
My 250 GB one crashed two times in 2 month ... But when I got 320 GB as replacement ... It is working well.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 30-07-2008, 08:11 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
be careful in the sense that don't use it as a portable drive. coz 640Gb is lot of data.
Old 30-07-2008, 09:48 AM   #10 (permalink)
filth is me
forever's Avatar
Go for the western digital, its more value for money and performs at par with seagate.
forever is offline
Old 30-07-2008, 11:31 AM   #11 (permalink)
The Frozen Nova
casanova's Avatar
IMHO, WD will be a better option
www.nerdweed.blogspot.com
casanova is offline
Old 30-07-2008, 04:46 PM   #12 (permalink)
Good Boy
george101's Avatar
i think i wil go for wd 640gb? plz correct me if i made d wrng decision.
guys i hav one more doubt. hw does hdd crash? is der anyway to knw it bfore it crashes. i dnt wnt to loose my data as it means a lot to me.
Old 30-07-2008, 08:15 PM   #13 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
i wud suggest seagate,wd is also good but chk if der is noise wen accessing data.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 30-07-2008, 08:32 PM   #14 (permalink)
Alter Bridge=GOD
^u mean wd makes noise?
i'd suggest one thing-don't use windows partition utility.use gparted.coz u will lose data in case ur windows hangs during that process.use good power supply or make sure u don't underpower ur system.
And if ur drive makes some clicking noise or any noise (be it any brand) backup ur data asap and get it RMA'd
Old 30-07-2008, 08:57 PM   #15 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^yes some wd models make noise compared to seagate
zyberboy is offline
Old 30-07-2008, 09:05 PM   #16 (permalink)
Alter Bridge=GOD
WD's always silent -even the first hdds they got in india were noiseless
u might have got a bad one
Old 01-08-2008, 09:31 PM   #17 (permalink)
Good Boy
george101's Avatar
Thanx for ur support guys.... i bought the WD......
Old 01-08-2008, 10:34 PM   #18 (permalink)
Bond, Desi Bond!
desiibond's Avatar
congrats for your purchase. how much did you pay?
post sisoft sandra benchmark results. that will help for comparisions etc.
Old 01-08-2008, 10:36 PM   #19 (permalink)
Alter Bridge=GOD
and HDTach
i have this hdd too so i'll try to do the same
Old 02-08-2008, 04:49 AM   #20 (permalink)
Good Boy
george101's Avatar
i got the WD for 4.6k....... am frm kerala......
Old 02-08-2008, 11:35 AM   #21 (permalink)
Alter Bridge=GOD
high..
4200 bucks everywhere
Samsung or the Seagate HDD ! My Advice---Seagate is better. dabster Hardware Q&A 14 29-12-2008 08:12 AM
help me buy 500gb external hdd tgpraveen Hardware Q&A 3 24-06-2008 12:09 AM
Seagate Barracuda 7200.11 500GB OR WD Caviar® 500GB SE16 sam9s Hardware Q&A 6 19-02-2008 10:30 PM
Help purchaisng the 500GB harddisk nawaz123 Hardware Q&A 24 19-01-2008 11:04 PM
