Old 29-07-2008, 06:12 PM   #1 (permalink)
unni's Avatar
Default Laptop Screen Resolution - Which to Choose
Hi,
I am planning to purchase Dell XPS M1530. I am still not able to decide on which screen to choose. In Dell site, they give option for the following:
1. 15.4" Widescreen WXGA (1280x800) TFT Display with TrueLife
2. 15.4" Widescreen WXGA+ (1440x900) TFT Display with TrueLife [+Rs. 1597.00]
3. 15.4" UltraSharp Widescreen WSXGA+ (1680x1050) TFT Display with TrueLife [+Rs. 4228.00].
I will be using the lappy for a lot of gaming. My main concern is how the heavy graphics demanding games will look like when they are played in a non-native resolution. For example, if I choose screen 3 and if Crysis is playable only at 1024 x some value, will it look bad? Please advice on this.
unni is offline
Old 29-07-2008, 06:23 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Laptop Screen Resolution - Which to Choose
1440x900 is a good balance between comfort viewing and good resolution. I'd recommend that. I'd recommend against 1280x800 as the display becomes too blocky and patchy. And I would never recommend 1680x1050 on a 15.4" widescreen. It'll surely kill your eyes.
Crysis at 1280x960 or even 1280x800 would be quite playable on 1440x900.
infra_red_dude is offline
Old 30-07-2008, 03:57 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
UltraSharp is delicious! It should definitely be given first preference. If you are a casual gamer, you won't mind the resolution issue. Most games are going to run in non-native resolution anyways on the laptop, right? Movies, text and overall experience on an UltraSharp screen is better than a normal glossy/matte laptop screen. But yeah, kinda sucks that you don't have UltraSharp option on the lower-res LCDs.
Sourabh is offline
Old 30-07-2008, 07:03 AM   #4 (permalink)
Point Blanc
acewin is offline
Old 30-07-2008, 09:23 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I would pick "15.4" Widescreen WXGA+ (1440x900) TFT Display with TrueLife [+Rs. 1597.00]".
1680x1050 is too much on a 15.4". Not at all recommended and is waste of money.
desiibond is offline
Old 30-07-2008, 10:14 AM   #6 (permalink)
unni's Avatar
Thanks guys for your replies. I will go for the second one (1440x900). In the US site, they are no longer giving the option for 1680x1050. Instead of it, they are giving 1920x1200 full HD screen
unni is offline
Old 30-07-2008, 10:42 AM   #7 (permalink)
Wire muncher!
WTF...?? 1920x1200 on a 15.4"???
Old 30-07-2008, 10:44 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
reading text on FullHD 15.4" is like watching ants crawling on earth from a space station
Old 30-07-2008, 05:30 PM   #9 (permalink)
radonryder's Avatar
the problem with 1280x800 is that you get these 2 black bars at the top and bottom of the screen...
I use the same resolution and find this quite irritating
I have created over a thousand blades.Unknown to death.Nor to life.Have withstood pain to create many weapons.Yet,those hands will never hold anything.so i pray,"Unlimited Blade Works"
radonryder is offline
Old 30-07-2008, 05:32 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ that should be only while watching movies. Right?
Old 30-07-2008, 07:58 PM   #11 (permalink)
Wire muncher!
^^^ Obviously
Old 30-07-2008, 08:15 PM   #12 (permalink)
gopz's Avatar
Yes, this was an option from quite some time!!
I wonder if the opticians have tied up with Dell to send them more customers
gopz is offline
Problem with screen resolution pradeepbp Open Source 11 13-05-2008 08:30 PM
screen resolution problem thecreativeboy Software Q&A 1 23-08-2007 11:41 AM
my screen resolution problem causes blank screen with error malav11 Software Q&A 1 17-08-2007 10:54 AM
Screen Resolution Change hailgautam Open Source 24 04-03-2007 03:12 PM
Can I change laptop screen resolution repeatedly? tech_lover Hardware Q&A 2 22-10-2006 01:36 PM
