Old 29-07-2008, 05:09 PM   #1 (permalink)
Default help me out figuring my pc
Hello guys.I am a hardcore gamer and I want to buy a desktop pc.Please give me details of gaming system around Rs.30,000 so that it could run the latest games like crysis,bioshock etc. Please giv config featured intel processors
Last edited by rockvenkatesh; 29-07-2008 at 05:12 PM. Reason: forgot something to mention
rockvenkatesh is offline
Old 29-07-2008, 11:49 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: help me out figuring my pc
Any dual-core based processor(Higher clock speeds would be better), 2*1gig. of DDR2-800Mhz RAM, 160-250GB(SATA-7200 rpm) HDD, motherboard with PCI Express 2.0 graphics card slot and 4 memory slots, 300+ Watts SMPS, a very large and AIRY cabinet,
above all a powerful graphics card which must be Directx 10 compatible based on chipsets like GeForce 8800GT card or above.
I am doubtful that you might get your gaming rig under this tight budget, If you can spend 5-10K more that would make a satisfactory setup.
Sooraj_digit is offline
Old 30-07-2008, 11:29 AM   #3 (permalink)
Pro Geeks
Micheal's Avatar
With this budget i can suggest u an upgrade solution not an entire desktop setup.
But dont lose hope, there's plenty of options.
My first suggestion, see this: Basic Guide Purchase a New System
Micheal
Status: Digitized since 2004
Micheal is offline
Old 31-07-2008, 08:44 PM   #4 (permalink)
Point Blanc
he says a desktop, monitor is not mentioned, so I will suggest with a good CPU config and come up a good graphix card.
acewin is offline
Old 01-08-2008, 09:14 AM   #5 (permalink)
Pro Geeks
Micheal's Avatar
rockvenkatesh have u gone thru chhoto cheeta's suggstions ???
Micheal
Micheal is offline
