Old 28-07-2008, 05:15 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Red face Any one there! LG HL-DT-ST DVD-RAM GSA-H55N Burning Problem!!!!!!!!!!!!!!!!!!!!!!!!
Hi, Guys,
I've a LG HL-DT-ST DVD-RAM GSA-H55N optical drive called "Super Multi" Brand
Is there anyone out there to help me with my DVD writer. Not burning dvds since I bought on 01 Jan 2008.
The Pros:
1. It reads few digit DVDs.
2. It reads well all sorts of CDs.
3.It burns CDs well.
4. Bios displays the drive as a DVD Writer Drive
5. DMA mode is on.
The Cons:
1. Most of the Digit DVDs (I mean the Digit 2008 DVDs) cannot be read.
2. I use Nero Express Edition 7.0 to write DVDs but the drive doesn't detect blank DVD, inserted before hand and ejects the drive tray apealing for the blank DVD disk to be inserted.
My system configuration:
1. 3.06 GHz Celeron Processor (pinless)
2. 945 Intel Chipset GCCR Motherboard
3. 512 MB DDR 2 RAM
4. SATA HDD 80 GB
5. Windows XP SP 3
6. LG DVD Writer
7. LG combo drive
rose tamang is offline
Old 28-07-2008, 05:41 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Any one there! LG HL-DT-ST DVD-RAM GSA-H55N Burning Problem!!!!!!!!!!!!!!!!!!!!
1. wrong section. reported.
2. get it replaced, or reflash firmware.
3. you had it for seven months, you couldnt burn, and you never bothered to replace it?
dheeraj_kumar is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/94252-any-one-there-lg-hl-dt-st-dvd-ram-gsa-h55n-burning-problem.html
Thread Device is not working properly (HL-DT-ST DVD-RAM GSA-H55N) | Microsoft Answers Forums | BoardReader This thread Refback 29-08-2010 02:08 AM
an unsolved problem with LG HL-DT-ST DVD-RAM GSA-H55N rose tamang Hardware Q&A 1 19-07-2008 05:30 AM
Problem with CD burning Shikhar QnA (read only) 7 19-05-2007 06:58 PM
DVD - Burning Problem!!! Aanand QnA (read only) 2 19-09-2005 10:59 PM
Problem with DVD Burning prasathvishnu QnA (read only) 1 12-01-2005 12:53 PM
