Old 28-07-2008, 11:24 AM   #1 (permalink)
Default Upgrade Help Required
I would like to upgrade my current PC(P4 2.4) to a C2D along with a MB & 2GB of DDR2 667 Ram.
I use it for programming, movies, internet, Linux, Video conversion.
I like to play games like Fifa, Cricket etc with a bit of eye candy(Not necessary ,only if possible). So would an onboard solution suffice?
Has any Motherboard got DVI connectivity?
Please help me.............
Budget: 12K.
I would also like to know the price of GeForce 8600 graphic cards.
nithishr is offline
Old 28-07-2008, 04:22 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Upgrade Help Required
get a Pentium Dual Core 2.0GHz for 2.9k,IP35-E for 4.9K,2*1GB DDR2 667 for 1.
8k.all these total to 9.6k.so u hav 2.4k in hand.8600GT costs bout 3.3-3.5k.no either xtend ur budget or get a 2nd hand 7800GT (some1s selling it in Bazaar).
hellgate is offline
Old 28-07-2008, 07:54 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
+1 for what hellgate suggested.
I'll suggest you to extend your budget & get a 8600Gt instead. It's dx10 compliant.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Upgrade Config Required .. BBThumbHealer PC Components / Configurations 13 29-06-2007 10:06 PM
Upgrade required antoniobc Hardware Q&A 4 25-06-2007 02:09 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
AGP Upgrade Suggestions/Advice Required ChetK QnA (read only) 22 01-08-2004 07:29 PM
