Old 28-07-2008, 10:14 AM   #1 (permalink)
Pro Geeks
Micheal's Avatar
Default Help required Understanding Chipsets
all i know about chipsets is that they r a set of specifications released by intel, amd, ... with which various vendors including the aforementioned manufacture motherboards
problem is: there have come around a plethora of them and its difficult to choose 1(only one). I have had tremendous help here choosing a motherboard (be it MSI, ASUS, GIGABYTE, ABit,...) but wat bothers me is dat wen i go to the vendor's shop they fire me with so many suggestions, i feel like doing my homework thoroughly
plz tell me the major and minor differences between these chipsets: X48, X38, P45, P43, G45, G43, G35, Q35, Q33, and finally the legendary P35
what i really dont understand is dat y is evry1 here (the xperts) suggesting boards based on P35 chipsets. I agree it performs but isnt it getting old???
pleeeeeez help guys
Micheal
Status: Digitized since 2004
Micheal is offline
Old 28-07-2008, 08:03 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Help required Understanding Chipsets
Go to specific chipset vendors website like intel,amd, nvidia for know about different chipset's features.
For mobo's 1st look what you can get in your local market. Note the model numbers & then go to the specific mobo manufacture's website. Or if you like online shopping then go to the mobo manufactures website 1st. Then choose what suits you. Then go to the online stores like http://www.newegg.com/ or anything else.
At last if you have a confusion ask in here
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 30-07-2008, 07:21 AM   #3 (permalink)
Point Blanc
dude in how much time does chipsets get old,
P35 is not old as you think. G33 chipset is even older. the 4 series you are talking about has been released very recently less than 2 months.
most of the time same chipset names are used until and unless there is no compatible proccy and they have made huge changes (915 and 945 chipsets currently).
915 and 945 were initally compatible for P4 and Pentium D proccies now they have been upgraded to include low end Intel proccies like 21xx and 4xxx.
Clear your doubts. P35 is nothing like legendry. Its just that after G33 and G31, P35 was introduced and there are good P35 chipset boards.
And people look mobos to recommend its just that the makers provide features according to the specification given by the base lines given by Intel, nVidia and Ati
acewin is offline
Old 30-07-2008, 11:18 AM   #4 (permalink)
Pro Geeks
Micheal's Avatar
just tell me in a nutshell, y is evry1 recommending or choosing P35 chipsets???
What about P45 based boards??
Micheal
Micheal is offline
Old 31-07-2008, 08:04 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
P45 boards are better than p35 boards ( future proof )
Here take a look @ one P45 board :
http://asus.com/products.aspx?modelm...11&l3=709&l4=0
topgear is offline
Old 31-07-2008, 09:26 PM   #6 (permalink)
Point Blanc
yup P45 chipset is better, and after the launch Asus and MSI have come up with good boards.
People do not always recommend P35 but they recommend abit P35E.
And all this being mostly due to cost.
Also, I do not think we can be much futureproof with the quickly changing hardware specs, only can think of. P45 mobos start with 6K
You have lesser choices currently
Look at MSI P45 Neo - F
Asus P5Q
Asus P5Q Pro
acewin is offline
Old 01-08-2008, 09:29 AM   #7 (permalink)
Pro Geeks
Micheal's Avatar
Yup both ASUS P5Q and MSI P45 Neo have caught my eye. They are great boards.
Some questions though:--
1> The boards support SATAII interface. Will they support my old SATAI HDD?
2> Unlike MSI P35 Neo Combo these boards do not have provisions for DDR3 RAM. I say i fear that in a couple of months if DDR3 becomes commonplace we r done for. Or do u guys think DDR2 is here to stay (budget is important 4 me)?
Do post ur thoughts
Micheal
Micheal is offline
Old 01-08-2008, 08:20 PM   #8 (permalink)
moshel's Avatar
its not that P35 is legendary....but rather its THE good board uptil now. As P45 has entered the market, P35 has fallen to the place of "comparatively old". If you had asked recommendations 1 year back, u would have heard names like G33, P35, 680i SLi, 965, 630i. and the year before that u would have heard names like 845, 865, 910, 915, DG101CC (dont remember if it was a board or a chipset) etc.
moshel is offline
Old 02-08-2008, 02:00 PM   #9 (permalink)
Pro Geeks
Micheal's Avatar
Do post ur thoughts
Anyone got answers to the queries above ???
And thanks moshel for that nifty info
Micheal
Micheal is offline
Old 03-08-2008, 03:12 AM   #10 (permalink)
Point Blanc
SATA is backward compatile so no issues there.
DDR3 currently are not not that better in price and performance against DDR2.
Priced alot high they do not give that much performance addition.
So it can be said DDR2 will surely stay.
Besides if you use a 64-bit OS you neednt worry much. You can increase as much ram u wannna put in, to make the performance rocking solid.
acewin is offline
Old 04-08-2008, 01:12 AM   #11 (permalink)
Pro Geeks
Micheal's Avatar
thanx acewin
Micheal
Micheal is offline
Understanding Windows Registry piyush gupta Tutorials 3 17-07-2007 04:30 PM
Understanding PC Hardware Gigacore Tutorials 2 17-04-2007 06:19 AM
Understanding the Enemy: The Top 10 Nastiest Malware Trends anandk Tutorials 10 14-01-2007 09:14 PM
Understanding DDR RAM timings/settings (to overclock) Rollercoaster Overclocking 4 06-11-2005 05:08 PM
