My monitor is getting freaky. It started a month or so back. I came home and noticed that nothing was visible on the monitor. After lots of checking, I went to the monitor firmware menu using the menu button on the monitor. I noticed that brightness, contrast, colour, etc were set to 0%. I fixed it and asked about it on IRC. Then forgot about it.
Recently, while using I see that brightness value keeps reducing with the display of the monitor firmware first flashing on the screen then all these things happening. I need to reset it by pressing the menu button again, but then the keys get all mixed up. I press left and it sometimes goes right and sometimes goes left. Same for right. Exit button also not working.
Today, the firmware went all drunk. I went to menu and it acted like the left button is permanently pressed - if I select something its value keeps going down and otherwise it keeps jumping between icons on the menu. Suddenly it stops. I need a fix. Please help.
I have Acer AC713 17" Colour Monitor.
I have never misused it or caused any damage to it. I don't know why all this started...
Apple iPad 2 16GB WiFi
