Old 27-07-2008, 07:20 PM   #1 (permalink)
KrishPuri.com
Default Buying a new MOTHERBOARD and PROCESSOR upto 25k??
Hi Guys,
I am thinking of buying a new motherboard and processor. My budget is upto 25k. If this is less, I can buy them 1 at a time.
I need a very high performance processor and motherboard. It will be required for all sorts of purposes...
I currently own a XFX nVidia Geforce 8600 GT GPU with 512 mb memory. I also own a 320 GB HDD and 2 GB RAM. Regarding the display, I recently bough a Dell SP2208 WFP widescreen 22" LCD monitor.
Which is the best Intel Core 2 Extreme?? How much does it cost?? I know that is very costly but how will it be if I go for an Intel Core 2 Quad processor?? What other processors are there that perform equally well?? What motherboard should I use with these processors??
Please answer my questions and also suggest me your opinions on different motherboards and processors that are equivalent to these...Also, please quote their prices.
Cheers
Krish
krish_puri is offline
Old 27-07-2008, 08:22 PM   #2 (permalink)
Pro Geeks
Micheal's Avatar
Default Re: Buying a new MOTHERBOARD and PROCESSOR upto 25k??
u seem to be filled to the brim with money dude
okay biznes time. if u r an overclocker and looking for an xcellent gaming platform and for that matter ne other rendering work go get an Intel C2D E8400, E8500. i wont suggest a quad-core bcoz the lower ones (atleast from intel) are basically two C2Ds slapped together. And although the higher ones r there there isnt heavy performance gain.
More importantly there aint enuf software around that can take advantage of quadcores. Some will come (or are coming) that incorporate support but tis just support and no real utilization. Even today very few softwares r there that can take advantage of the dual-cores we hav today.
For motherboard i'd suggest (4 u ) ABit IP35 Pro, IX38 QuadGT; MSI P7NSLI PLATINUM, P35 PLATINUM COM, X48C PLATINUM, P45 Platinum; ASUS P5K64 WS.
Go look these up for urself.
Micheal
Status: Digitized since 2004
Micheal is offline
Old 27-07-2008, 09:00 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Wait for nehalems.
No use of spending so much now.
Even if u do,within few months these are obsolete due to nehalems.
Regarding quads-they are much more future proof.and there's not much difference in performance in apps which only support dual core.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 27-07-2008, 09:04 PM   #4 (permalink)
KrishPuri.com
Originally Posted by nish_higher View Post
Wait for nehalems.
What are nehalems??
Old 27-07-2008, 09:51 PM   #5 (permalink)
http://en.wikipedia.org/wiki/Nehalem_(microarchitecture)
kuki_295 is offline
Old 27-07-2008, 09:55 PM   #6 (permalink)
Originally Posted by krish_puri View Post
What are nehalems??
wikipedia, Intel
ToyTowner is offline
Old 28-07-2008, 01:44 AM   #7 (permalink)
ancientrites's Avatar
i say every product becomes obsolute in some or other day.If you are in hurry i suggest you buy intel E8500 and asus p5Q mobo or if you like sli ones go for 750i mobos from asus or msi.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is offline
Old 28-07-2008, 09:49 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ Yes. Every product becomes obsolete. But Nehalem is a huge architectural change that you should not ignore. Its something like an advancement from Pentium to Core architecture.
# Integrated memory controller supporting DDR3 SDRAM and between 1 and 6[citation needed] memory channels
# Integrated graphics processor (IGP) located off-die, but in the same CPU package[4]
# A new point-to-point processor interconnect, the Intel QuickPath Interconnect, replacing the legacy front side bus
# Simultaneous multithreading, which enables two threads per core. Simultaneous multithreading has not been present on a consumer Intel processor since 2006 with the Pentium 4 and Pentium EE. Unlike the SMT implementations on the Pentium 4 and the Atom, SMT on Nehalem is referred to as 'MTT'.[5]
# Native quad and octo (8) core processors[6]
# 32 KB L1 instruction and 32 KB L1 data cache per core
# 256 KB L2 cache per core
# 8 MB L3 cache shared by all cores
# 33% more in-flight micro-ops than Conroe[7]
# 2nd level branch predictor and 2nd level Translation Lookaside Buffer[7]
# Modular blocks of components such as cores that can be added and subtracted for varying market segments[8]
If you look at the bold text, it's an architecture that's worth waiting for.
@krish_puri : If you are ready to put 25k for proccy and mobo. You should definitely wait for Nehalem.
According to a preview from AnandTech "expect a 20 - 50% overall advantage over Penryn with only a 10% increase in power usage. It looks like Intel is on track to delivering just that in Q
desiibond is offline
Old 29-07-2008, 12:31 AM   #9 (permalink)
KrishPuri.com
thnx guys...will definitely wait!!
When do you think it's gonna come out??
Old 29-07-2008, 08:52 AM   #10 (permalink)
filth is me
forever's Avatar
http://www.techpowerup.com/66657/Int...em_Launch.html
forever is offline
motherboard upto 5k ayush002 Hardware Q&A 6 18-06-2008 03:45 PM
Help with Processor + Motherboard abhipal Hardware Q&A 12 08-08-2007 02:24 AM
buying new mobile budget upto 12000/- niks999 Buying Advice 13 22-08-2006 11:37 AM
Help needed for buying motherboard, Processor and RAM montylee Hardware Q&A 6 07-11-2005 09:27 AM
Regarding buying AMD 64 bit processor guhanath CPU / Motherboards 8 02-04-2005 09:48 PM
