Old 26-07-2008, 11:26 PM   #1 (permalink)
Default Warranty of Dynet Ram
Hi,
I have purchase Dynet400 DDR Ram 2 years Back but now its giving problem.. Can it be exchanged . if yes then from where can i get it changed or should i buy the new one......
Thanks and Regards,
Rajan ..
Mr.Rajan is offline
Old 28-07-2008, 02:32 AM   #2 (permalink)
master is here
Default Re: Warranty of Dynet Ram
depending upon ur vendor the dynet ram comes with both 1year and 3 year warrenty
if its still under warrenty then u cn go to ur dealer from where u bought the ram he will give u new one
coz dynet ram have often only sign warrenty by vendor not company warrenty
pankaj4687 is offline
Should i go for dynet RAM? karthik55859 Hardware Q&A 9 04-06-2007 01:34 AM
Regarding IPod Warranty.... amitskale Audio 35 30-04-2007 11:50 AM
