Old 26-07-2008, 02:06 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default System does not boot,BIOS hangs mid way
Hi,
My system does not boot, the BIOS is hanging at Loading of bootloader stage.
once i remove my newly replaced SATA hdd the system boots fine and does not hang anymore. after removing the HDD i can also boot via Bootable CD.but the PC does not start if HDD is plugged in.
My system specs:
AMD Athlon 64 3000+
MS K8MM-V
1GB Drr 400Mhz Ram
Nvidia Geforce 6200
80 GB sata hard drive ST380815AS
Problem
My HDD crashed, so i replaced it with new one. installed it correctly. it booted fine. loaded windows on it in morning. now since evening. it does not boot.
I have checked the SATA-I compability jumper, its set at factory default i.e 150GB/s
also, the RAID config utility, which appears just after POST srenn is detecting the HDD correctly.
It just hangs while loading bootloader.
Please help
gary4gar is offline
Old 26-07-2008, 04:13 PM   #2 (permalink)
Default Re: System does not boot,BIOS hangs mid way
I can't be sure if this is the cause of your problem. But most mobos require that, if you're using a single SATA drive, it has to be set to non-RAID in BIOS. It won't boot otherwise.
pimpom is offline
Old 26-07-2008, 04:19 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
its a single HDD and no RAID have been setup..
its just plain vanilla SATA hdd
what i think is, its the onboard SATA port thats culprit.
but i am not sure, how to confirm this?
[edit]
I downloaded Seagate Seatools and tried booting with it. it does not boot with hdd attached.it hung at InitDisk function
so i removed the HDD and seatools booted fine. after that i again install the HDD *without* poweriting off my PC.
and guess what it worked!!
and i tested the drive with Short and long test. and it passed both the test without any trouble
gary4gar is offline
Old 27-07-2008, 09:05 AM   #4 (permalink)
Try resetting bios to default values....disable SMART etc.
Let there be music.....
sashijoseph is offline
every 2-3 days my PC hangs up on the BIOS screen iinfi Hardware Q&A 4 31-05-2008 04:00 PM
Upgraded Bios! Now system won't boot Hackattack Hardware Q&A 18 12-02-2008 09:39 AM
XP hangs on boot screen hitman050 Software Q&A 9 11-06-2007 08:39 PM
System hangs..help linardni QnA (read only) 3 10-02-2007 03:59 PM
Boot process hangs akshar Software Q&A 3 04-07-2005 04:56 PM
