Old 25-07-2008, 04:17 PM   #1 (permalink)
Question DVD Writer tooo slow!
My friend has a DVD writer from LG.
It used to work fine but from a few days, it has become too slow.
It took 2 hours to copy DVD and that too failed when verifying.
I think it may be DMA problem but I am not able to figure it out properly.It always writes at about 2350 KBps even at 8X for a DVD.We checked the settings in the Device manager but found nothing.
It is the primary slave.
Any help.
anshul is offline
Old 25-07-2008, 06:35 PM   #2 (permalink)
Beta Waves's Avatar
Default Re: DVD Writer tooo slow!
Open device manager and look for primary IDE channel (as you say its connected to primary channel).. right click and select properties. in that click on advanced settings and see if the transfer mode is set to PIO. If it is change it back to DMA.
Most often this wont work because windows will disable DMA permanently when it encounters serious errors while reading or writing. So better right click an the channel and select uninstall and Reboot the system windows will automatically install with new proper settings. It will be set to DMA.
I am Back....
Beta Waves is offline
Old 25-07-2008, 06:47 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Try this -
http://svp.co.uk/helpdesk/index.php?...nloaditemid=15
dheeraj_kumar is offline
Old 25-07-2008, 07:22 PM   #4 (permalink)
We tried that first thing and saw that currently it was PIO and for DMA it was Enable if available.
This didnt change much. I'll try the second.
Thanks!
anshul is offline
Old 25-07-2008, 07:28 PM   #5 (permalink)
Here Since 2003
Indyan's Avatar
I had also faced a similar problem recently. I tried one of those vb scripts to reset my dma status. That solved the problem.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 25-07-2008, 08:17 PM   #6 (permalink)
One more problem.........
I have a DVD RW and a combo drive.
But when I installed the DVD RW, I had to remove the combo drive.
Then I attached it to the same IDE cable(it has 3 sockets), but it never gets detected.Power is there but it is not detected.
Even if it is detected as a secondary master it doesnt work.
anshul is offline
DVD writer damn slow..I got IMATION dvd writer.. roonie Hardware Q&A 9 09-01-2008 08:05 PM
dvd writer getting very slow. mgupta Hardware Q&A 6 23-07-2007 09:29 PM
Y USB transfer tooo slow???? dittualex Peripherals 1 15-11-2005 05:38 PM
download speed tooo slow suddenly!, :( pls help legolas Internet & WWW 4 10-11-2005 03:14 PM
slow cd writer varunbhide QnA (read only) 6 11-04-2005 08:16 PM
