I bought a new laptop B1900 series.
12.1 Inches
Intel Duao core
1gb ram(512 hp, 512 trescend)
its very slow & freezes frequently.
what may be the reason?
requesting for the solution.
hope u dont have ny virus in ur pc
try scanning ur pc & if sill the problem go for os re install & if still problem persists them kick the @$$ of person frm whom u purchased ( i mean seller & dont say that its gifted )
if u re install windows then i wud suggest u to delete all partitions then recreate all partitions.
