Old 24-07-2008, 11:36 PM   #1 (permalink)
moshel's Avatar
Default PC freezes without warning
since last week a very odd thing is happening in my pc.
while im working, the PC just hangs without warning, i am not even using something heavy, just the normal opera or utorrent.
when the pc hangs, the mouse pointer also freezes and the keyboard also dont work. all i have to do is give a long press at the start button to make it shut down.
when i restart it, there is no scandisk, the pc starts normally and i dont even get a message saying that "your pc has recovered from a serious error". its starts as if nothing happened.
btw i use XP. and this thing happens once in a day. either in the morning or the evening (those times only i start my PC).
pls tell me wat m8 be the problem.
thanks.
P.S. one more post required to reach 500! yippee.
moshel is offline
Old 25-07-2008, 01:15 AM   #2 (permalink)
Default Re: PC freezes without warning
There is more than one possibility:
Bad sectors - run surface scan.
Bad memory - test with memtest86.
Loose connections or defective HDD cable - check or swap.
Overheating - accumulated dust or defective fan.
Defective PSU - swap with a known good one if possible.
pimpom is offline
Old 25-07-2008, 01:28 AM   #3 (permalink)
SMPS/power supply please
realdan is offline
IE Freezes for a moment.. patkim Software Q&A 5 13-01-2008 01:48 AM
Does your IE6/7 freezes ? Faun Chit-Chat 29 08-12-2007 10:31 PM
Quake 4 freezes Shloeb Gamerz 12 12-11-2007 12:35 PM
my winXP freezes!! mario_pant Software Q&A 4 13-10-2005 09:25 PM
Pc Freezes! vij26 Software Q&A 6 21-03-2005 11:23 PM
