Old 24-07-2008, 12:30 PM   #1 (permalink)
Default usb protection
HI
I want to protect my usb port. Basically i want to do is nobody can copy the data from my hdd to attached usb. but they can copy the data from usb to my hdd. How to do that?
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
buntythecool is offline
Old 24-07-2008, 01:29 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: usb protection
Dude if u r talking about flash drives then i have a solution
1. convert ur flash drive to ntfs
2. go to the properties of your removable disc in the tab for security there you should find some really good stuff about preventing from read or write or delete and would surely help for your ques.
But if u r talking about the port, even i have no idea.
Sooraj_digit is offline
Old 24-07-2008, 01:54 PM   #3 (permalink)
i got the solution.............
http://www.eternalmoonlight.net/2008...or-unwritable/
Thanks for the help
Dell 3yr Complete protection Vs 1yr Complete Protection... Suggestion needed sakthirajesh Buying Advice 5 07-12-2007 03:01 AM
Best Protection.... siddhantmutha Software Q&A 58 14-08-2007 09:47 PM
CD Protection !!!! bajaj151 QnA (read only) 3 03-06-2007 11:14 PM
protection !!!! jmit QnA (read only) 8 06-03-2007 03:13 PM
protection for cd/ dvd swap_too_fast QnA (read only) 4 10-11-2005 06:24 PM
