Old 24-07-2008, 10:30 AM   #1 (permalink)
Exclamation Strange problem.. HCL Busybee P-III PC.
Hi,
One of my friend has HCL Busybee PC with
- MB: MSI Model : MS 6368
- Pro.: 1.0Ghz P-III
- RAM : 133MHZ 256MB SD
- HDD: 80GB Samsung
- DVD Writer: LG 16X
- LAN CARD & Modem
Now the problem is that, when he starts the comp. after the post. beep computer doesn't boot Windows XP. Instead it continuously beeps for a while.
I have tried removeing the cards LAN & Modem. still same problem.
Once I reset BIOS to Failsafe Defaul. Then it worked. Then I added all the cards One by one and started the PC. IT worked.
Next morning computer refuses to boot.
Should BIOS Update resolve the problem.
PLEASE HELP.
mantahn is offline
Old 24-07-2008, 11:28 AM   #2 (permalink)
Default Re: Strange problem.. HCL Busybee P-III PC.
All these problems due to lose connections. check all the connections specially hdd cable. check the ram is properly fitted in slot. check system,if it boots in xp, add cards one by one.
sdhiraj1 is offline
Help Me out with this strange problem kunaltech Software Q&A 4 20-02-2008 05:45 PM
Strange Problem!! ayush_chh QnA (read only) 5 19-12-2007 01:24 PM
strange HDD problem blackleopard92 Hardware Q&A 9 12-09-2007 10:26 PM
strange problem....... vandit Hardware Q&A 11 30-10-2006 12:26 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
