my dvd writer does not shows the dvd movie files in the drive but its plays the dvd on the cyberlinkpowerdvd
wats the problem pls tell me
i also cant copy paste the dvd files also due to this prob
just try playin any other DVD movie..if the same problem is there is not...
bcoz....sometimes the content is not visible due to problem in file system
but the file is still accessible...happend with my friend also,he played the movie
thru VLC media player...
the drive not showing ne files then how can i play it in the vlc player
on autoplay its says the dvd is blank
it only plays on the powerdvd
just popin the DVD...open VLC then select the drive name: like F: etc
it will start playin the data...
