Old 24-07-2008, 12:13 AM   #1 (permalink)
Default Better Processer!!
i got 1 nyt 2 choose between an amd turion X 2 2.0ghz or an intel core 2 duo 1.8Ghz...
id lik 2 noe wich of d 2 is betr n d pros n cons of each!!!
thnx a lot in way advance...hopin 2 recieve gud replies b4 dawn morw as m travelin 2 india morw evnin...
~Peace ouT~
~PunK~
~PunK~ is offline
Old 24-07-2008, 11:48 AM   #2 (permalink)
Pro Geeks
Micheal's Avatar
Default Re: Better Processer!!
hey buddy i'm too looking for upgrade solutions. i've been gathering info from all over this forum so here's my suggestion:---
Intel Core2Duo E8500, E8400, E8200 (newly launched)
These babies r based on the Penryn core (45nm fabrication process). I'll recommend them bcoz they r the top-of-the-line, serious revisions have been made and r an overclocker's delight (rock solid gaming performance)
They may xceed ur budget but u'll get huge returns
Micheal
Status: Digitized since 2004
Micheal is offline
Old 24-07-2008, 11:51 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
~Peace ouT~
~PunK~
Looks like you are going to buy laptop. If yes, Intel Core2Duo has a definite advantage over Turion X2.
desiibond is offline
Old 26-07-2008, 06:40 AM   #4 (permalink)
Point Blanc
well AMD gernerally means you want something between intel high end core2Duo and intel low end.
Pro of AMD over intel is certainly better power management and low cost.
Otherwise AMD Turion 2.2 would not come near to 5xxx series or other high end proccy.
But certainly would prefer it over 2xxx series laptop proccies(like 2370 and others)
acewin is offline
prob with processer or motherboard??? hansraj Hardware Q&A 5 30-10-2005 11:26 PM
