Hello Guys ,
Facing this problem for a really long time now ! Purchased a Sony DVD-RW about 2-3 months back and attached it to my Samsung DVD-RW in the system using same IDE cable ( i purchased a new cable at that time .... i m still having the old one which i used with Samsung DVD-RW !) .
Since then , whenever i try to install windows , whether its Vista or XP , it doesn't take less than a hour and a half for the installation to get completed ! Earlier , it took a max of 30 mins for both operating systems !
I tried each and every method like configuring the BIOS for the best settings , PIO and DMA mode etc ! Moreover , I disconnected my new Sony DVD-RW and tried to install windows like i did earlier with my previous hardware ( only i didn't revert to the old cable ) . I thought now installation will be fine but the problem still persists !
So , i want to ask whether the new IDE cable can be at fault in this case ?
Waiting for a quick reply to get the matter resolved !
Thnx in anticipation !
BBThumbHealer
