Old 22-07-2008, 11:54 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Default LCD flickering
When I play music on my 5.1(Creative T6060) I sometimes actually see the pixels or shall I say crystals of my screen getting distorted thus producing a fuzzy as the beat goes on.
Plasma_Snake is offline
Old 23-07-2008, 12:17 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: LCD flickering
maybe it catches vibrations...keep the woofer away
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-07-2008, 10:48 AM   #3 (permalink)
Indidiot
My room is small so can't keep the woofer away, the only viable solution is to not to turn up the volume while the screen is ON and listen music at low volumes.
Old 25-07-2008, 08:12 AM   #4 (permalink)
toofan's Avatar
Solution 1.
Check the mobile signals near the LCD.
If it doesn't work then
Solution 2
Your monitor might not be configured well.
Check the setting of the monitor. Brightness level. Contrast level. Focus settings and resolution settings this will definitely solve the problem. There would be a Monitoring tool with your LCD. Just use it.
toofan is offline
Old 25-07-2008, 08:29 AM   #5 (permalink)
Indidiot
All the measures you have told are for actual flickering and perceptible image distortion. Mine is a LCD TV and the flickering is not actual, its just the fuzziness of text only when high volume bass music is played, rest of the time its all fine and dandy so the only solution to this is to keep the bass levels down.
Old 26-07-2008, 06:22 AM   #6 (permalink)
Point Blanc
right any flickering problem due to mobile singlans and all is only in CRTs. And generally you can solve this problem by correct power supply and degaussing the CRT, if it flickers.
For LCDs cannot flicker they can just shutdown or give distorted and bad display and in short can be called fuzziness. are you using separte power source for both or same(I mean UPS). because certainly going on high volume sound and bass means your are asking more power input. Is that affecting your LCD. and does high sound from the woofer really affects the LCD Display like that.
acewin is offline
Old 26-07-2008, 09:58 AM   #7 (permalink)
Indidiot
Thumbs down Re: LCD flickering
I know its the Subwoofer that causes its fuzziness due to its bass, no power issue as UPS is of 1KVA! I guess the close proximity of screen to the subwoofer is the root cause of this and solution, if one can call it that, is to keep volume down.
Old 26-07-2008, 10:32 AM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
keep the sub woofer on a piece of foam to damp the vibrations.this cud solve ur prob to some extent.
hellgate is offline
flickering problem with 17" tft anksin Hardware Q&A 1 04-12-2007 09:46 PM
Flickering ! ! ! ax3 QnA (read only) 3 10-01-2006 04:19 PM
My PC screen is flickering sush5 QnA (read only) 6 20-09-2005 10:16 AM
Monitor Flickering!!! Biplav QnA (read only) 8 14-09-2005 02:49 PM
flickering firefox GunshotSilence Internet & WWW 7 08-09-2005 05:39 PM
