Old 22-07-2008, 01:11 PM   #1 (permalink)
rameeze's Avatar
Default need help in shutdown command
how can i create a batch file to take input from users as time in command "shutdown -s -t <TIME>
rameeze is offline
Old 22-07-2008, 06:51 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: need help in shutdown command
shutdown -s -t %1
thats it... save it as shut.bat or something... and "shut 1000" is 1000 seconds delay etc. its called command line arguments. You can use the choice command in batch scripting but you can only choose between a list of options, as far as i know. Google for more help.
dheeraj_kumar is offline
Run Command pvsraao Hardware Q&A 2 22-11-2007 12:11 AM
COMMAND & CONQUER UPDATE - EA shoots out Command & Conquer 3 demo techtronic Gamerz 1 28-02-2007 12:18 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
use of shutdown -i command mako_123 QnA (read only) 1 06-10-2005 07:03 PM
