Old 21-07-2008, 11:32 AM   #1 (permalink)
Evolving Rapidly...
confused's Avatar
Default How much amount of PC133 SD-RAM, will Intel Solano 815i support?
Hi guys, i have an old PC, which i need to make use of. It already has 2x128MB SD-RAM. One of these is 100Mhz, other 133Mhz. The mobo has three ram slots overall....
So my question is: will the pc function if i add a 256MB stick??? or will all sticks need to have same capacity??
Also, what will be the total amount of RAM supported??
Please help me out.
Thanks.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 21-07-2008, 11:49 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: How much amount of PC133 SD-RAM, will Intel Solano 815i support?
yes of course it will fuction and though with more noticable speed, get your self 133 Mhz module. But you have SD ram slots, a bottleneck, SD ram are the costliest and the toughest to find in shops. reply to ur ques: it is the "frequency" which matters NOT "capacity" for ram modules to work glitch free. Max. ram supported by your mobo must be at least 2 gigs(ONLY A GUESS!!). For an advice have new pc if possible(only take it as a advice, not seriously). Hope u r happy.
Sooraj_digit is offline
Old 22-07-2008, 12:36 AM   #3 (permalink)
IIRC, the Intel 810 chipset family, which includes the 815, supports up to 512 MB RAM, so you should be okay with adding 256 MB. I'm sure about the 810 chipset, but even if the 815 is different, it will not be lower than 512 MB because the 815 is more advanced than the 810.
They don't have to be all the same "capacity" - 128 + 128 + 256 gives you 512 MB.
Regarding speed, if you install more than one RAM stick, they will all run at the speed of the slowest one, 100 MHz in your case.
pimpom is offline
Old 22-07-2008, 04:52 AM   #4 (permalink)
Evolving Rapidly...
confused's Avatar
thanks guys for the answers.... as it turns out, the mobo supports only 512mb memory.
forgot to mention that i also have a nvidia 5200fx 128mb card. so when i plug in the 256 mb ram (bought it yesterday for 500 bucks), there is no display...... guess i will have to plug out one 128mb ram card.
dude, i bought a high end pc recently, but wary of taking it to my hostel. so need to reburbish my PIII.
here is my config:http://thinkdigit.com/forum/showthread.php?t=87334
confused is offline
Old 22-07-2008, 01:34 PM   #5 (permalink)
No, it doesn't work that way. The memory on you graphics card is used in another way, and does not change the amount of RAM you can use via the motherboard RAM slots.
The absence of display must be due to other reasons. Make sure all all memory sticks are firmly inserted, and check all other connections. It could also be that you "new" 256 MB is defective.
pimpom is offline
Doesn't Intel DG965RYCK board support IDE HDD ? Madhavan Hardware Q&A 1 28-03-2007 07:11 PM
does intel mobo support vista sagargv Hardware Q&A 18 14-03-2007 01:41 PM
Intel opens 3D support for Linux!! JGuru Technology News 30 12-08-2006 10:31 PM
Intel 915 Support win98? valtea CPU / Motherboards 11 08-07-2005 05:30 PM
Do Intel Support D915GAV Windows 98 navisangha Software Q&A 2 27-02-2005 01:02 PM
