Old 21-07-2008, 10:15 AM   #1 (permalink)
No longer here..
Default Suggestion for motherboard for a P4 3GHz LGA 775
Hi,
My friend has a P4 3Ghz LGA 775 Cpu and a "Mercury PVM7 Pro V1.0" motherboard.Two days ago he switched off the PC and went to sleep.The next day when he tried to switch on the pc wont boot.There is no display on the monitor and no beeps as such.The processor fan is spinning and the battery seems to be OK.We suppose the mobo went kaput.Now the final step is to send the mobo to the neighbourhood pc clinic.In case the mobo is truly fried can you guys suggest a new mobo for the following combo.
Processor : P4 3GHz 775 LGA
RAM : 512 MB DDR2 533Mhz
Expansion: AGP /PCI-ex ????
Thanks in advance...
PS:If possible please do mention cost also.Budget mobo please ..
indian_samosa is offline
Old 22-07-2008, 12:12 AM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: Suggestion for motherboard for a P4 3GHz LGA 775
Dont panic there are many things to try out:
1. pull out all the ram modules from the mobo and then switch on, then shut down, put in the module back in place and then switch it on again.
2. repeat the same step but with the battery.
3. re-insert all the cable and power plugs(ONLY IF YOU HAVE EXPIERIENCE)
But pal, if these dont solve your problem here's the list of BUDGET motherboards:
NVIDIA 680i/650i CHIPSET BOARDS:
1. Zebronics ZEB-650i SLI Rs. 4.8K
2.Galaxy 650I LT Rs. 4.8K
INTEL INTEGERATED GRAPHICS
1. Gigabyte GA-G33M-S2H Rs. 5950(BEST BUY SILVER 2007)
2. MSI G965MDH Rs. 6300
HOPE THIS HELPS
And also increase your RAM to gigas if condion permits you wont regret 1gig would cost just 1K.
Last edited by Sooraj_digit; 22-07-2008 at 12:15 AM. Reason: Automerged Doublepost
Sooraj_digit is offline
Old 22-07-2008, 02:55 AM   #3 (permalink)
damn busy...
utsav's Avatar
^^u call all those mobos budget motherboards
@american_samosa get a 946gz chipset board for about 2.2k
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 22-07-2008, 10:07 AM   #4 (permalink)
No longer here..
^^ thanks guys for the suggestions.
@sooraj_digit ... we did all those stuff and finally took it to the nearby pc shop where they also told us the mobo is dead.
@utsav .. ... We found 3 mobos below 3K mark here.One is mercury 945 with pci-ex+onboard(cost 2.8K).Second one is Gigabyte 945 (cost 3K) and third one another model of mercury.Its upto my friend to decide on these now ..
Thanks guys....for the help.
Old 22-07-2008, 10:16 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
wats the budget of ur friend...
if ur friend doesnt have GCard then go 4 nvidia chipset mobo they r best in onboard
gaming
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 22-07-2008, 10:26 PM   #6 (permalink)
No longer here..
Thanks all ...^^ he got a Mercury mobo with Nvidia nforce 7050/610i chipset for 2.8K.It has pci-ex also ...
Old 06-08-2008, 10:36 AM   #7 (permalink)
geek on a roll
abhisek_bsws's Avatar
I am going to upgrade also with p4 3 ghz lga 775 proccy...is asus p5kpl-vm wid pci-e good enough???...my hardware vendor is quoting it rs.2850+vat
BACK WITH A BANG
abhisek_bsws is offline
motherboard suggestion raviramgopal Hardware Q&A 1 02-04-2008 07:45 PM
A good gaming MotherBoard-CPU combo suggestion required. DeSmOnD dAvId Hardware Q&A 6 30-07-2007 05:11 PM
Need Motherboard Suggestion.. dreams CPU / Motherboards 29 08-04-2007 05:02 PM
Motherboard & CPU Bundle - Suggestion Required sainit Hardware Q&A 2 08-04-2007 11:14 AM
