| Forum |
#1 (permalink) |
Please suggest a good internal TV tuner card. Main idea is to use it with Vista Media Center (or maybe later with MythTV/Knoppmyth or some other media center distro). I'm getting a Pinnacle Remote Kit for Vista from amazon.com to go with the card. Link for the kit is pasted below. http://www.amazon.com/Pinnacle-Remot...6321670&sr=1-2 Main requirements for the TV tuner card are 1) Should work with Vista Media Center (this is the main requirement). It should work with the media center remote also 2) Should give good quality picture and sound. Please suggest a good tuner card. Budget is within Rs 2500 (preferably). Bumpy...bump....nobody?? Last edited by PaulBarber; 20-07-2008 at 12:51 PM. Reason: Automerged Doublepost |
#3 (permalink) |
Bond, Desi Bond!
dude. I don't think card's bought in US will work in India.
USA TV Format : NTSC India TV Format: PAL B So, don't buy it in USA. Just to go local dealer and buy it.
My first blogspace: http://desiibond.blogspot.com |
#4 (permalink) | |
Anyways most of the cards support NTSC and PAL, so even cards bought from US should work here. |
#5 (permalink) |
Bond, Desi Bond!
Okay. If you are getting from local dealer, then this is the best one for you I think:
http://www.pinnaclesys.com/PublicSit...dows+Vista.htm
#6 (permalink) |
^^ Thanks...looks like good option. But I have already ordered the media center remote kit separately, so I wouldn't need the complete kit. I'll see if I can get the "PCI stereo TV tuner card" separately (without the media center remote and blaster)
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Windows Media Center VISTA Compatible TV card! | freshseasons | Software Q&A | 11 | 02-08-2007 11:12 AM |
| Tv tuner card that is media center supporting | Hardware Q&A | 8 | 20-11-2005 04:26 PM | |
| TV Tuner for Windows Media Center | rajpreet123 | Software Q&A | 2 | 15-11-2005 08:19 PM |
| TV Tuner for Windows Media Center ? | rajpreet123 | Software Q&A | 2 | 15-11-2005 07:35 PM |
| TV Tuner for Windows Media Center | rajpreet123 | Hardware Q&A | 4 | 15-11-2005 05:09 PM |
