Old 18-07-2008, 11:18 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Smile A ques on RAM
Can i add 1GB ddr2 RAM, currently there is 512 MB on the PC.
There r only 2 slots for RAM. The chipset is of VIA.
Model no: MSI k9mmv, i think.
Thanx.
Stealth mode, I like that. Kool.
Blogging at:
A Techies Blog
saqib_khan is offline
Old 18-07-2008, 11:36 PM   #2 (permalink)
jal_desai's Avatar
Default Re: A ques on RAM
do u have 2 X 256 MB ram modules? if yes then u have to remove one of them and attach 1 GB RAM module...
or if u have 1 X 512 MB ram modules then in the one empty slot u can add 1 GB ram module ... make sure they have same frequency and both are DDR2
TechExplorer.in
jal_desai is offline
Old 18-07-2008, 11:43 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Read motherboard manual to find what and how much memory is supported by your motherboard.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 18-07-2008, 11:54 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
Total 2 GB max supported.
@jal_desai
I have 1 stick of 512 MB RAM.
Blogging at:
A Techies Blog
Old 19-07-2008, 12:09 AM   #5 (permalink)
@jal_desai
Then, as jal_desai said, you can add a single 1GB DDR2 stick.
pimpom is offline
Old 19-07-2008, 12:26 AM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
@jal_desai
And what do u mean by "same frequency"?
R u talking abt Mhz.
e.g. If i have 512 MB DDR2 667 Mhz then i will add another 1 GB DDR2 667. Am i correct here?
Blogging at:
A Techies Blog
Old 19-07-2008, 02:02 AM   #7 (permalink)
smile's Avatar
Cool Re: A ques on RAM
Yes ur wright .Always it s better to add the same frequency Ram so that no problem will occur
SR
smile is offline
Old 19-07-2008, 02:22 AM   #8 (permalink)
i dont live, i survive
visor619's Avatar
all chips like ram, processors come with a specific frequency.. for eg. ur ram might be a 667 mhz one or a 800 mhz one, the latter being better.. so if ur existing RAM is of 667 mhz, then u have to put a RAM of 667 mhz only... unless u want to celebrate diwali a bit early... also take care that the difference between ur 2 RAM chips is not much... a 512mb and a 1gb ram wud go fine, but a 256 mb ram with 1 gb might create heating problms... nevr try o put a 128 mb wid a 1gb RAM guys!!! i did it once, n enjoyed a little boom boom boom....
*HOPE for the BEST,PLAN for the WORST*
*GAMING is LIFE*
*KEEP what u KILL*
visor619 is offline
Old 19-07-2008, 04:53 PM   #9 (permalink)
15.0 GHz
VarDOS's Avatar
i think u shoud sell u r 512 MB and just buy 1 GB
Bcause If In Future U Upgraded U R RAM Then It Will Be Easy.
VarDOS is offline
Old 21-07-2008, 11:30 PM   #10 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Yes, of course you can gift your pc with a more gb of ram. Keep a check on reputed brands only like corsair, zion etc. you must take identical frequency of ram you have i.e. 667 Mhz. For an advice i must say that if you can alter your budget and get a new 1gb DIMM of frrequency 800 Mhz and exchange your single 512mb(667mhz) for a single 1gb 800 Mhz(of same brand) by paying a little less for the another 1gb stick which would sum up ypurram upto 2 Gigs it would be really benificial since you will have the gain of dual channel ram with more frequency.
Yes, of course you can gift your pc with a more gb of ram. Keep a check on reputed brands only like corsair, zion etc. you must take identical frequency of ram you have i.e. 667 Mhz. For an advice i must say that if you can alter your budget and get a new 1gb DIMM of frrequency 800 Mhz and exchange your single 512mb(667mhz) for a single 1gb 800 Mhz(of same brand) by paying a little less for the another 1gb stick which would sum up your ram upto 2 Gigs it would be really benificial since you will have the gain of dual channel ram with more frequency.
Last edited by Sooraj_digit; 21-07-2008 at 11:31 PM. Reason: Automerged Doublepost
Sooraj_digit is offline
Some technical ques. pirates1323 Hardware Q&A 3 03-05-2008 09:24 PM
career ques iMav QnA (read only) 14 03-06-2007 01:03 PM
some ques. abt w810 n 610! mananknl Mobiles and Tablets 6 01-05-2007 09:55 AM
Vista RC 2 Ques... BBThumbHealer Software Q&A 3 05-03-2007 03:32 PM
RAM ???? D ques is ........ VICH 1 ???? futuristically_ancient QnA (read only) 3 23-10-2004 08:59 PM
