Old 18-07-2008, 10:16 PM   #1 (permalink)
Default USB Drive Partitioning....
Can any body, give solution to this problem... yes I want to make partition in my USB drive..
Thanks in advance.
MaxPY is offline
Old 19-07-2008, 02:26 AM   #2 (permalink)
i dont live, i survive
visor619's Avatar
Default Re: USB Drive Partitioning....
by USB drive, what are u referring to?? a pen drive or an external hard disk drive???
*HOPE for the BEST,PLAN for the WORST*
*GAMING is LIFE*
*KEEP what u KILL*
visor619 is offline
Old 19-07-2008, 04:57 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
if u have a external HDD then use partition magic
VarDOS is offline
Old 19-07-2008, 05:32 PM   #4 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Not Sure about STICK Drives but you can try Windows In-built Partitioning tool.
Goto Control Panel->Administrative Tool->Computer Management->Disc Management
Here Select your Pen Drive or External Hard Disk or whatever, then Right Click that partition and select Delete partition, after that create the two new ones. If you are using Vista, then you can also split the Drive into two easily.
My pen drive has partitioning software bundled with it so never tried, guess you might look for Partitioning Magic also
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 19-07-2008, 06:10 PM   #5 (permalink)
Tech'ing life seriously!!
sude's Avatar
if urs is an transcend pen drive (i suppose u are talking abt pen drives) try mFormat utility from transcend website..
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 20-07-2008, 08:51 PM   #6 (permalink)
Pen Drive...
Windows XP Disk Management console -----???
Its shows Removable Disk ... ie you can NOT create more than ONE...
partition magic 8.0 ko to mera pen drive dikhta hi nahi......
Q. till unanswered.
MaxPY is offline
Partitioning your hard drive in Windows Vista narangz Tutorials 23 07-05-2010 09:32 AM
Partitioning a pen drive?? harpoon QnA (read only) 13 20-02-2008 07:38 AM
Partitioning d Hard drive rahul_jaiswal31 Software Q&A 2 24-12-2007 10:56 AM
Partitioning hd....??? Pragadheesh QnA (read only) 4 14-02-2007 05:00 PM
Hard Drive Partitioning- XP Home Edition s18000rpm Hardware Q&A 4 15-07-2006 09:32 PM
