| Forum |
#1 (permalink) |
C2D 7200 PALIT N73V 2GB DDR2 ZEBRONICS CABBY(BIJLI) DVD-RW (ANY BRAND) 250GB HDD 9600 GSO 384MB(PALIT) pleaes guys tell me if the following choices i made r correct and also could u please recomend a good psu under 2500 to power this system |
#2 (permalink) |
Point Blanc
what is your total budget if any. and your location.
Proccy C2D 7200 @5800 Would recommend a better mobo. Check Abit ABit IP35-E = 5400, besides I do not really have much idea of mobo, but looking at the specs of Palit N73V, I would suggest you to get a better mobo 2 GB DDR2 800 MHz Transcend/Kingston(Single stick) @1900 250 GB from WD DVD-RW from Samsung/Sony/Asus a SATA drive. (will recommend ASUS DRW-2014L1T @1250) GPU choice is good. @6500, if you are not buying a 512 MB card which would come if you spend about 2K more PSU Cooler Master Extreme Power 460 @ 2K nothing better than this for current config you got here. |
#4 (permalink) |
Point Blanc
if the mobo is good then its gr8. Besides your GPU selection is also decent, and in 25K you would be able to get a real good overall config.
Mobo has only 2 DIMM slot, and other available port made me say that, if you wanna try expansion ahead then it can hamper it. no DVI no HDMI port etc. But you really cannot think of much in 2K. But make sure you buy single stick of 2GB RAM so that if you latter on wanna make it to 4GB it does not makes a problem for you wasting of RM if you try 2x1GB module. |
#5 (permalink) |
Rebooting
May this can help
rebooting ChotoCheeta.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| ^(*)^ Advice Needed ^(*)^ | power_8383 | Mobiles and Tablets | 46 | 28-07-2008 10:21 PM |
| Building New Rig, Advice Needed.. | madassinhell | Hardware Q&A | 1 | 05-08-2007 01:42 PM |
| Expert Advice Needed !! | coolboy_n | Software Q&A | 12 | 07-03-2007 01:40 PM |
| Advice needed | arora_parth | QnA (read only) | 5 | 08-09-2005 09:19 AM |
| Advice needed | arora_parth | QnA (read only) | 4 | 03-09-2005 12:21 PM |
