Old 17-07-2008, 10:44 PM   #1 (permalink)
Default Wireless USB modem for a MacBook
What type of USB modem from which service provider works best on a MacBook using Mac OS?
Any pointers?
samirmd is offline
Old 17-07-2008, 10:52 PM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: Wireless USB modem for a MacBook
What exactly are you trying to do? In any case, I've seen both Reliance and TATA usb things being used with OS X. Just depends on which of the two services gives better range in your area.
If you a seasoned macboy, then join up with us on the Official Apple Thread.
I'm like a bird... :)
goobimama is offline
Old 22-07-2008, 12:19 PM   #3 (permalink)
I am just trying to use the Reliance Netconnect usb. I plug it in nothing happens. In the network configuration it is not detected as a device.
samirmd is offline
Old 22-07-2008, 12:22 PM   #4 (permalink)
 Macboy
goobimama's Avatar
You need a modem script for that. Ask your apple store if they can provide you with one.
Old 23-07-2008, 10:45 AM   #5 (permalink)
Smitten by Computers..
raptorz's Avatar
You can use BSNL EVDO. Cheap and great speeds.
There were somethings Man was never supposed to know, for everything else there is Google..
raptorz is offline
wireless modem+router, how ? virus_killer Networking 1 16-06-2008 10:58 AM
Want to buy a ADSL Modem cum Wireless Router paragkalra Networking 5 22-02-2008 02:56 AM
Wireless Router + ADSL Modem ? gsmsikar Networking 6 19-11-2007 09:50 PM
Making ADSL modem wireless jack// ani Networking 3 12-12-2005 01:08 AM
