The most easy solution for this would be to get a VGA (D-sub) cable from market.
The genuine reason for flickering is that the S-Video cable is more prone to interference by external agents( as in here the AC power supply).. SO you get flickering whenever you connect it to AC.
I also connected My LCD TV to computer(Desktop) by S-Video cable. And the picture was Pathetic. I couldn't see a single thing. Then I got a VGA cable and wola It worked like magic.
Before getting a VGA cable make sure that your lappy supports monitor output (I think yours will have it anyway!!). The port will look same as the monitor output in a desktop.
**And for audio get a separate audio cable from market. Its easily available. Then connect it from the Lappy's "headphone out" to TV's "Audio Input". You will have sound coming from TV(although it might be somewhat weak.. Confirm that
Do tell if it works. 'cause it worked with my dad's laptop
