Hi Guys
Hi I have a Dell Inspirion 6000 Laptop and have bought a Techcom 813 TV tuner card.
I have taken an analog cable connection ; now the issue is
- Though in TV my neighbor get around 150 odd channels , I get only 18
- Of these 18 only 4 /5 channels has great picture quality rest are noisy (grainy) these channels seem ok in a TV.
- Thirdly when I select Scan all option in Tuner card software it Scan only upto 80 channels (125 is the limit for favorite channels)
- It does not catch all the channels & stores even non transmitting channels – which result in usage of only around 18 channels.
- First time I did an autoscan I got around 18 channels & few days later when I did another scan I lost few channels and got other channnels ( they are still in the TV)
Can some one advise me on whats happening ?
And
1)Is there a way to scan all the available channels without the auto scan stopping automatically when it reaches 80 odd
- why are some channels clear while some are noisy (too grainy)
- If I take a DTH (digital connection ) will I face the same prob
- Or due to the presence of a Desktop/decoder Box of DTH provider I can watch all the channels ?
- Every time I start my Tuner software it comes in NTSC format ( which makes the Picture black & white) and every time i have to manually select it to Pal to get colour – however even after applying & saving the settings goes off every time I close the software.
- Lastrly I see a list of PAL option starting from PAL-B to maybe PAL-H – which one should I use ?
Thanks
Dimitrz
