15-07-2008, 12:09 AM
Problem with my New Samsung 943NMX 19" widescreen
I am facing a display problem of text but my image are great but little stretched or say wide. I am using 1024 X 768 resolution but the exact resolution is 1400 X 900. My motherboard is MSI VIA K8M800_CE + VT8237R Chipset with Via/S3G Unichrome Pro IGP.
So what to do, if i install a extra Graphic card the problem can be solved.
15-07-2008, 12:11 AM
Dreamweaver
Re: Problem with my New Samsung 943NMX 19" widescreen
maybe ur inbuilt graphics do not support widescreen resolutions.. get a graphic card.
15-07-2008, 12:17 AM
But my mother board is old say one and half years, i can get the graphic card for that and what graphic card to buy.
15-07-2008, 02:17 AM
No pain....No gain
Update the gfx driver and the lcd are meant to be used at their native resolution, that's why the text seems to be stretched. Else install a gfx card, ur mobo has AGP 8X. Is this your mobo http://global.msi.com.tw/index.php?f...4&maincat_no=1
15-07-2008, 07:45 AM
At Hell's Disq
did u try changing the display res to the native res?
15-07-2008, 09:31 AM
Bond, Desi Bond!
I think it's only a problem with resolution. Set it to it's natvie resolution. You will lose lot of detail if you set it to non-native resolutions.
15-07-2008, 12:28 PM
Originally Posted by john_the_ultimate
Many thanks for the advice but i don't have the 1440 X 900 resolution in my system and if i install the gfx card i will have the native resolution or not i am confused, but i have a AGP slot in my motherboard. and what is mobo?
I don't have the native resolution 14400 X 900 in my system.
My display is set to 1024 X 768 and i do not have the 14400 X 900 in my system which is needed.
Reason: Automerged Doublepost
15-07-2008, 12:54 PM
Bond, Desi Bond!
hmm. See if updating drivers might work else buy a GPU
15-07-2008, 03:02 PM
No i updated all the bios drivers etc but nothing happened. What is GPU?
15-07-2008, 03:11 PM
No pain....No gain
mobo = motherboard
GPU = Graphic Processing Unit aka graphic card
The only choice it seems is to get a gfx card. Get some low-end geforce 8 series card (8400gs or 8600gt etc.) cost would be around 2-5k.
15-07-2008, 03:17 PM
mobo = motherboard
Thanks, but you are sure that i will get the correct resolution 1440 X 900 and at the same time my text will not get spoiled.
mobo = motherboard
What will be the price of a Motherboard + Ram + Processor which could support my Sumsung 19" widescreen monitor.Should be the cheapest because you know i will upgrade.
15-07-2008, 11:27 PM
No pain....No gain
Most intel/nvidia/ati onboard gfx controller (say 2 years old) support 1440*900 resolution. Donno why, yours isn't?
Anyways, if you are thinking of an upgrade then tell us ur budget.
16-07-2008, 08:51 AM
Bond, Desi Bond!
^^ Because his is entry level VIA's onboard gpu, which sucks big time when it comes to performance
16-07-2008, 11:12 AM
No pain....No gain
Yes did notice that he has a VIA onboard gpu but didn't think that it would suck this much
16-07-2008, 03:48 PM
Tribal Boy
