Old 11-07-2008, 08:15 PM   #1 (permalink)
alkesh_007's Avatar
Default Laptop freezing after startup
Hello,
HP BUSINESS NOTEBOOK NX6325
AMD TURION MOBILE X2 1.6GHZ PROCESSOR
WINDOWS XP PROFESSIONAL SERVICE PACK 2
1 GB RAM
My AC adaptor had stopped working so I bought a new one. Today after plugging in the
new adaptor, once the laptop started, after 5 mins it freezed and i could not shut it down
by ctrl+alt+del. Had to shut down by power button. Booting again caused same problem.
Then i restored the system to earlier state but problem persisted. Tried to run it in safe mode and it works fine.
But in normal mode it hangs up after startup.
What could be the issue?
Thanks.
alkesh_007 is offline
Old 11-07-2008, 11:08 PM   #2 (permalink)
anubisX's Avatar
Default Re: Laptop freezing after startup
Is it a new issue after using the new power adapter or the problem was there previously ?
anubisX is offline
Old 11-07-2008, 11:19 PM   #3 (permalink)
alkesh_007's Avatar
This prob came up after using new adaptor. Laptop was off for almost 3 days
as the old power adaptor stopped working. I run laptop all the time on adaptor
as I dont have battery at the moment.
Its running fine in safe mode with networking. I am running the McAfee scan right
now. Once the scan finishes, will try and see if it works fine in normal mode again.
Old 11-07-2008, 11:22 PM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
@alkesh_007: Goto HP customer care site and have a chat with the expert. I had a similar battery problem before and I solved it using the instructions given by the chat agent. they have the exact solution to every problem.
Charan is online now
Old 14-07-2008, 05:39 PM   #5 (permalink)
alkesh_007's Avatar
The problem still persists. It works fine for few mins after starting and then freezes.
Sometimes, it works fine for hours and then freezes again.
I did system recovery using HP's recovery disk but still same prob.
Today, I contacted HP customer care by phone. First they asked me
to run the diagnostic tests on memory and hdd. Both tests passed.
After that they are saying you need to replace the motherboard.
It works fine in safe mode. It doesnt freeze. Should I replace the motherboard?
I still doubt, there could be any prob with motherboard.
Now I will try and clean the RAM and see what happens.
Old 18-07-2008, 03:05 PM   #6 (permalink)
alkesh_007's Avatar
*Update*
Had removed RAM and reseated it. Still the problem continued.
Updated BIOS and other drivers and freezing stopped. Since then I have not
experienced any hangs.
Also installed windows XP service pack 3.
There is one new issue - systems slows down too much. CPU usage is 100% most
of the time. If one application, say Firefox is running it would take up 50-70% of CPU
usage.
Any help appreciated.
Thanks.
Old 18-07-2008, 07:17 PM   #7 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ Dude.. have a chat with HP support.. not phone call but "chat"
Old 18-07-2008, 08:47 PM   #8 (permalink)
alkesh_007's Avatar
@Charan..
My notebook is not supported by the active chat session.
It does not recognise the product number and serial number.
Old 19-07-2008, 12:06 AM   #9 (permalink)
u dont have battery and run on adaptor only!
where did you get the new adaptor? is it a reputable brand? is it replacement from HP?
as regards the system slowing down, it might be some virus or spware or malware, etc
use HP recovery again and see...
realdan is offline
Old 19-07-2008, 02:37 AM   #10 (permalink)
i dont live, i survive
visor619's Avatar
@ alkesh
if ur task manager is showing 100% usage, it may not necessarily be a hardware problem.. as u hav already said, after updating ur drivers, the "freezing" problem stopped.. it may be due to trojans... try this, open task manager>click on processes> choose explorer.exe>right click>end task.. now the explorer wil close.. after that click on 'new task'>browse>run any application that was previously taking up 50-70%.. chances are, it wil run smoothly now.. if it does, press ctrl+alt+delete to bring up the task manager, goto"new task">type "explorer.exe" and hit enter... again, u will c that the process,"svchost.exe" is running on 90-100%... if this or part of the above happens, it is clear that there are memory trojans in ur system.. a clean format would solve the problem... the process looks lenthy but wud take less than 5 mins and wont harm ur system in any way.. worth trying atleast
PS: Mc Afee sucks big time... try kaspersky or nod32... nod32 is heavy on resources though...
*HOPE for the BEST,PLAN for the WORST*
*GAMING is LIFE*
*KEEP what u KILL*
visor619 is offline
Old 19-07-2008, 06:21 AM   #11 (permalink)
Point Blanc
as I have seen this model I can precisely say it hs got battery
Really from where did you get this adaptor from.
Try systemchecks like defrag and what are the processes at startup, check msconfig.
what antivirus are you using.
acewin is offline
Old 19-07-2008, 02:33 PM   #12 (permalink)
I run laptop all the time on adaptor as I dont have battery at the moment..
r u saying u dont have battery means "no battery plugin" or it is there but not working and not getting charged or it is not charged now
realdan is offline
Old 19-07-2008, 02:42 PM   #13 (permalink)
alkesh_007's Avatar
@realdan
I run on adaptor because I have to buy a new battery. Its very costly here in UK.
Adaptor bought directly from HP.
I have McAfee Security Centre installed. I have done full system scan and found no viruses.
@Visor619
I will see if it works.
Thanks..
**Update**
I did what Visor619 had suggested. But it didn't work.
I removed Windows XP SP3 and system is back to normal. No more sluggish
performance and no more 100% continuous CPU usage.
Thank you all for help.
motorokr e6 freezing....please help ! esumitkumar Mobiles and Tablets 4 03-07-2008 06:04 PM
New System Freezing.... ECE0105 Hardware Q&A 9 29-05-2008 05:02 PM
My PC is freezing frequently...help Edburg Hardware Q&A 13 28-11-2007 12:46 PM
XP freezing NIGHTMARE Software Q&A 4 03-10-2007 12:44 AM
HELP ME!!! MY PC IS FREEZING sreevirus Software Q&A 5 10-10-2004 12:47 AM
