11-07-2008, 05:36 PM
ATI 4850 VGA Cooler
Hi guys my friend had ordered a Sapphire 4850 GPU, all the reviews say it runs hot so he wanted a aftermarket cooler for 4850, googled & found no cooler for 4850. Will the 3850 cooler fit for the 4850.
Please suggest, budget 1.5k
11-07-2008, 11:08 PM
Re: ATI 4850 VGA Cooler
wait for manufactureres to design their own dual slot cooler, then things wud change.
G3: XPS M1530 |
FZ 16.
12-07-2008, 11:45 AM
i suggest you buy ThermalRight VGA Cooler HR-03 GT it will suffice the cooling needs.
28-11-2008, 06:26 PM
is it available here in India? what is the price? what about zalman 900 or 100?
29-11-2008, 04:24 AM
ANGEL OF DEATH
i m using sapphire 4850 dual slot cooler its runs cool
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
29-11-2008, 01:18 PM
what are your temps?
29-11-2008, 05:11 PM
Better get an Accelero S1 Rev.2. Works like a charm & drops the temperature insanely. Mine used to idle at 76 deg & load would be 105 deg. After applying the Accelero & an 120mm fan, it dropped to 43 deg idle & barely crosses 53 degs on load.
V for Vendetta
29-11-2008, 05:52 PM
you use additional fan or using it in just passive mode? also does removing and installing custom heat sink void waranty?
29-11-2008, 06:02 PM
I am using an additional fan as well just to have some more cooling on it. Don't want to risk anything this time. You can use a passive cooling without the fan as well & it's very efficient at that.
Removing the stock heatsink will void the warranty. If you can remove everything with utmost care & also retain the stock heatsink, you can re-assemble it later on if card dies out & needs to be RMA'd. Most likely they shouldn't be able to trace the process unless it's physically damaged during this process & it's clearly visible.
V for Vendetta
29-11-2008, 10:59 PM
now thats risky!!! but I think I will get away with it. For how much did you got that 4850? and what about accelero s1?
30-11-2008, 04:13 AM
ANGEL OF DEATH
47 C
30-11-2008, 09:49 AM
I got it when the card initially launched so the price was a staggering 11.9k for the single slot cooler. The Accelero set me back by 1.6k.
V for Vendetta
01-12-2008, 04:10 AM
ANGEL OF DEATH
^^ when u purchased ur card
01-12-2008, 09:53 AM
7th August 08.
V for Vendetta
19-01-2009, 09:41 PM
Could anyone please tell me where in india might we buy thermaltake or arctic cooling or zalman or zerotherm coolers for graphics cards. All places i looked for only had coolermaster or thermalright coolers.
20-01-2009, 01:29 AM
Depends on where your location is. Here in Mumbai, Thermalright is available but no sign of Arctic cooling in retail hardware stores. I suggest looking for an online purchase. There are plenty of online sites these days that can source you this stuff from abroad.
V for Vendetta
20-01-2009, 07:42 PM
In the books..Studying
Go to lynx-india.com
