Old 11-07-2008, 01:06 AM   #1 (permalink)
himadri_sm's Avatar
Default Virus in my USB drive
i have a kingston data traveller 8 gb pen drive..everytime i try to open it i get the following error--'windows cannot access the specified device,path or file.you may not have appropriate permissions to access the item"
AVG Resident shield gives the following error-"
"file name : h:\system\driveguard\driveprotect.exe
threat name : virus identified worm/autoit.bqm
detected on open
after this either i use heal or move to vault or ignore..i'm not able to access my pendrive..if i heal or use the move to vault options & double click my drive..i am asked to select the program to use to open it..if i ignore it..the problem remains the same..only formatting the drive brings things back to normal..but it keeps on occuring, ........how do i stop this?
himadri_sm is online now
Old 11-07-2008, 01:48 AM   #2 (permalink)
Default Re: Virus in my USB drive
It seems your computer is also infected with the virus and keeps re-infecting your USB drive even if you format it.
One thing you can try is Trend Micro's HouseCall. Trend Micro are the makers of PC-cillin and TM Internet Security anti-malware products. "Housecall" is their free online service for scanning your computer for all sorts of malware - viruses, spyware, worms, trojans. The URL is http://housecall.trendmicro.com
pimpom is offline
Old 11-07-2008, 05:23 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Did you try formating the drive in a linux machine (or via LIVE CD), then formatting and reinstalling windows on YOUR machine, then using it ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 23-02-2009, 12:22 AM   #4 (permalink)
Cool Re: Virus in my USB drive
Hello Friends,
I knew that the all people really distrubed with PEN DRIVE virus which easily transfer in the pen drive/system. How to stop and delete before making changes in the system .
I can read many problems about that.
SOLUTION
Here the solution of all the query is AUTORUN EATER
Download the autorun eater
After installation
The start sound is great.It's really enjoying by you
The Scan Priority is High on the right click in the system tray icon.
Enjoy this software which is shield of the computer and the laptop.
It deny the virus which is automatically transfer in the system. Delete it.
For example: virus name snake.exe.vbs which directly going in the Windows directly. The dangerous viruses(exe) stopped only by this software.
goel.suraj is offline
Old 02-08-2010, 11:06 AM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
autorun eater is the best thing we have now for autorun.inf
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 02-08-2010, 12:24 PM   #6 (permalink)
Cool Buddy's Avatar
Always keep a folder named autorun.inf in your pen drive and ask others to create the folder before you borrow someone else's pen drive. This folder prevents the creation of autorun.inf file in the pen drive and hence the virus cannot spread. in case, the folder cannot be created, the pen drive is already affected by the virus. try this in that case:
open notepad and write the follwing
del /f autorun.inf
md autorun.inf
attrib +h +s autorun.inf
save this file as xyz.bat and place it inside the pen drive's root. Now open the file, it will run in a command prompt window.
This will create the folder named autorun.inf & make it invisible (normally) to prevent accidental deletion. Hope it works
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
How to remove latest.exe Virus from pen drive?? rajaramvengayil Software Q&A 15 18-03-2009 10:39 PM
Virus Present in C drive NiluGeek Software Q&A 3 02-05-2008 03:21 PM
My pen drive got newfolder.exe virus sganesh Software Q&A 8 07-04-2008 06:48 PM
A query about a virus in a flash drive. krazzy Software Q&A 21 08-03-2008 10:07 AM
can a virus cause problem in dvd drive????? tango_cash Hardware Q&A 6 31-07-2007 12:41 AM
