well planning to upgrade...i am into cell phone repairs n most of the time the software i use need a lot of usb connection to flash phones..so as of now i have a budget of 22000 on me....plz can u suggest a config which wud satisfy me by power as well as have a major amt of usb ports...
thanks in advance
Clifford Goa
thanks in advance
Clifford Goa
My Intel DG33 motherboard has 6 onboard USB ports and support for 6 more making it a total of 12 USB 2.0 ports. I've never run out of ports on this system of mine.
the above mentioned suggestion are ok...but the hadware that i plug in the usb extract a lot of power from them...so wat i am looking is that even if i use a hub..i want it with a power supply separately
