Old 10-07-2008, 08:20 AM   #1 (permalink)
chanchalchatt's Avatar
Default 2nd ram slot does not work
My mb model is MSI PM8M-V.It has 2 ram slot and i have a 256mb of ddr-1 ram which is in the 1st slot.I want to buy a anather ram of 512 mb ddr-1,so i change my ram 1st ram position into the 2nd slot ,then i start my computer but it does not start. Please help me
Advanced thanks
chanchalchatt is offline
Old 10-07-2008, 12:18 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: 2nd ram slot does not work
me have the same problem with my office system, but removing one slot either 256 or 512 works fine. 256+256 works but 256+512 doesn't work, dunno wht the exact problem is
tried a lot by changing slot vice-versa, clean the connection circuits but at last failed, now using 512mb.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 10-07-2008, 11:33 PM   #3 (permalink)
In your case I think ur mobo has a max limit of 512MB. Older mobos had limits like this. Check ur mobo specs.
gulgulumaal is offline
Work, Work & Work.... u get no raise ! vish786 Chit-Chat 5 14-09-2007 03:49 PM
AGP Slot dhooomketoo Gamerz 5 01-11-2005 11:15 AM
no agp slot..... gauravakaasid QnA (read only) 5 28-07-2005 07:37 AM
AGP slot kaboodle QnA (read only) 8 24-06-2005 12:53 AM
AGP Slot navisangha QnA (read only) 2 08-10-2004 12:43 PM
