Hey guyz, I have problem with scandisk of windows....I have 4 drives (c,d,e,f) and few days ago, windows scandisk was checking my F drive for errors everytime I start my computer, but then I reinstall my windows XP SP2, But again the problem continues.........PLZ help me....
There is no second chance.....!!!!
How about running this command :
Start > Run > Cmd {Press Enter}
On the command prompt type this :
chkdsk F: /f /r {Press Enter}
Windows is checking errors on your hard disk again because the volume is marked as having some errors. Reinstalling Windows will not change the volume (your partition) attributes unless you format the concerned drive.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
