When I switch on my computer I get a notification from a tray icon that it has found a new hardware. I find 'PCI Simple Communications Controller' to be an error in the Device Manager. After I restart the computer there is no notification, and the error in the Device Manager is gone. What is that 'PCI Simple Communications Controller'?
My computer sometimes shuts down and restarts by itself and mostly I get a DOS kind of screen which says something like : BIOS ROM CHECKSUM ERROR. PLEASE INSERT SYSTEM DISK INTO FLOPPY DRIVE A. I don't have "FLOPPY DISK"!!!
I tried loading default CMOS settings by removing and putting back the battery inside the CPU, but I still face the same problem.
Sometimes I get a 'Windows encountered a problem' dialog box (which has buttons 'Send Error Report' and 'Dont Send') and I find mini<some.number>.dmp and sysdata.xml to be faults through that dialog box. This seems like a graphic card related problem, I suppose.
My computer specifications:
Intel Pentium 4 HT (3.00GHz), 512MB RAM, 80GB HardDisk, Windows XP Professional Media Center Edition 2005. I recently ( in March 2008 ) added nVidia GeForce 7200 GS (256MB DDR2, 64BIT, PCI-E).
The problems started after I added the graphic card. I suspected that its a driver related problem but ruled that out after installing the latest drivers for my card. My OS is also regularly updated.
Please ask if you want some more info.
Can you help me out, please?
