Old 09-07-2008, 01:27 PM   #1 (permalink)
lethalweaponforever's Avatar
Default Processor
I have a intel dual core 1.8 ghz processor.
sppose i exchange it for an intel core 2 duo 2ghz or 2.4 ghz processor how much will i have to pay................
lethalweaponforever is offline
Old 09-07-2008, 08:10 PM   #2 (permalink)
moshel's Avatar
Default Re: Processor
dude....give us some info of ur current rig (what mobo u using) and wats ur budget....
moshel is offline
Old 10-07-2008, 02:28 PM   #3 (permalink)
i have
OS:Win XP Service Pack 3(courtesy our good friends at Digit)
CPU:Intel 1.8 Ghz dual core E2160
RAM:1 gb
HDD:80 gb
DVD drive: 52x
Video: Intel 82945G Express Family Chipset, 128 MB
Sound: DirectX9.0 compatible sound card
DirectX: DirectX9.0c
Old 10-07-2008, 02:48 PM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
why do u want to change ur procy?if ur not much into procy intensive tasks and gaming u wont feel a gr8 diff bet ur current procy and a C2D @ 2Ghz.
hellgate is offline
Old 10-07-2008, 05:17 PM   #5 (permalink)
Lets Do It!
amrawtanshx's Avatar
About 2000 INR ......Assuming both are new (Comparing ur processor with E4600 )
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 10-07-2008, 06:31 PM   #6 (permalink)
@amrawtanshx
My processor is abt 2 months old
@ hellgate
need to change my processor mainly for games like Virtua Tennis 3 and Top Spin 2 and for animation
Old 10-07-2008, 06:51 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
ok.then get a E7200 or if u hav the budget then a E8400 though u'll hafta change ur mobo if u get these proccies
hellgate is offline
Old 10-07-2008, 07:15 PM   #8 (permalink)
Instead of changing processor try to add PCIE graphic card
M L B is offline
Old 10-07-2008, 10:05 PM   #9 (permalink)
moshel's Avatar
^^^+1 to that...
moshel is offline
Old 11-07-2008, 09:12 AM   #10 (permalink)
What is the difference bet. PCI and AGP cards and how to identify which one i want
Old 11-07-2008, 08:20 PM   #11 (permalink)
moshel's Avatar
forget AGP....
u will have to buy a PCI-Express card....in simple words...look out for these..
8600GT....abt 5k (i have heard as low as 3.5k)
9600GT...abt 9K
8800GS...abt 10k
ok im not too sure abt the pricing. but these are the model numbers u should look out for. just like motherboards, these graphics cards are available from all manufacturers like.. Asus, XFX, MSI, Palit etc.
moshel is offline
Processor Name??????Big Question.1 Processor 3 Names vutonium Hardware Q&A 12 05-07-2007 11:07 PM
Which is the best Processor? overdose_14 QnA (read only) 5 23-03-2006 10:20 AM
Do i need a new processor???? moshel Hardware Q&A 10 04-02-2006 10:46 PM
Which processor is better munnabhai Hardware Q&A 2 10-11-2005 10:45 PM
OS for AMD 64 bit processor Chitra CPU / Motherboards 4 18-09-2005 11:46 PM
